Old 01-05-2015, 05:28 AM   #31
The antenna booster does two things--it provides power to the antenna and it switches between antenna and cable. To use the cable from the rear compartment for satellite, you will need to remove it from the antenna booster and route it to the satellite receiver. Then add a new coax from the satellite receiver output to the cable input on the antenna booster (and turn booster power off). (Or use a different output on the receiver like HDMI and connect a new cable to the TV and switch the TV to the new input used by the cable).
On the 2012 Sunseeker with only front TV, there is no coax loop to disconnect; you have to remove the cable from the back of the antenna booster.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
