Old 12-28-2015, 04:52 PM   #1
Do you run your RV periodically during the winter?
I am off this week so I went and checked on my Sunseeker. My brother found a leak at one of his windows on his Thor so I wanted to check mine. Fortunately everything was just like I left it. Since I was there I drove the RV and ran the generator for nearly an hour. I plan to do this a couple more times until camping season starts again.
Does anyone else do this?
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 12-28-2015, 05:09 PM   #2
Citrus County, Fl.
GL1800Rider's Avatar
Onan recommends running the generator under 2/3 load for an hour each month. If I don't camp each month I at least start it or drive it as well. If you are not going to use your fuel much you should add a fuel stabilizer so it does not go bad. I try not to have fuel any older than 3 months.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 12-28-2015, 05:26 PM   #3
RedLdr1's Avatar
I drive our unit on a long loop at least once a month. Between drives, at roughly the two week point, I run the genset for an hour or more, under load, while I check out the unit. That schedule keeps the house batteries at a decent charge level and lets me check out everything a couple times a month.
Wayne and Christine
2020 Sunseeker MBS 2400Q On Order
RedLdr1 is offline   Reply With Quote
Old 12-28-2015, 05:37 PM   #4
I topped off the tank and added fuel stabilizer before I parked it. I always use it on engines that will sit for a few months.
Old 12-28-2015, 06:18 PM   #5
A32Deuce's Avatar
As long as you run it long enough to get everything at operating temp. Not a problem. This way, any moisture is removed from everything.
A32Deuce is offline   Reply With Quote
Old 12-28-2015, 07:19 PM   #6
Wandering's Avatar
Run both the camper & generator in my in the drive way. Kinda tucked away & tough to take out for a drive.
Any suggestions to put generator under load. I turn AC on but only the fan runs in 30 degree weather.
Forester 2451s
Forester 2451s
Wandering is offline   Reply With Quote
Old 12-28-2015, 08:00 PM   #7
Store RV inside a tight and dry but unheated garage. Use fuel stabilizer in fuel tank and run main engine to operating temp every 2-3 months. Remove fuel and fog the generator engine thus I do not run it periodically. Since I almost never camp without hookups I haven't run the genset for years. A couple times a year I spin the genset on the starter to keep it lubed and free.
ATVer is offline   Reply With Quote
Old 12-28-2015, 09:50 PM   #8
Citrus County, Fl.
Forester 2451s
You can run a space heater or if you have a heat pump and it's warm enough for it to work you can run that.
99 Terry 31G
Old 12-29-2015, 01:58 PM   #9
rsscully's Avatar
I run the heat pump, and converter tops off the batteries. I also start the chassis engine if I am not able to drive it and let it run until the engine comes up to temp (usually about 10 minutes)
rsscully is offline   Reply With Quote
Old 12-29-2015, 03:41 PM   #10
Hoglou's Avatar
Gmacklem..
Yes, I keep ours active every week. I do winterize the water about jan 15 after our winter beach trip. The question is how much of a pain is it to drive around and return? I guess you cant park at home?
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
winter
