Old 05-09-2016, 09:48 PM   #1
Dometic fridge
Should the fridge operate with ONLY shoreline power?
GMax is offline   Reply With Quote
Old 05-09-2016, 09:51 PM   #2
TURBS's Avatar
Domestic fridge
No it should operate on propane as well.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-09-2016, 10:42 PM   #3
I guess I need to rephrase the question....Will it operate (gas or shoreline) without the house battery turned on?
Old 05-09-2016, 10:51 PM   #4
One more correction...I meant to say Dometic RV fridge.
Old 05-10-2016, 12:41 AM   #5
benagi's Avatar
No. You need to have the house battery on because the Fridg needs 12 volt.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 05-11-2016, 06:06 AM   #6
The refrigerator will operate when on shore power or when the generator is running and the house batteries are off if the convertor is working. The convertor will supply 12 volts to the coach.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 05-11-2016, 06:34 AM   #7
Flybob's Avatar
The fridge control board needs 12V to power the control board. That 12V can come from battery or 110V AC supplied to the RV converter. This is the case for both electric or propane.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-12-2016, 12:01 AM   #8
benagi's Avatar
Dometic fridge
If I'm on shore power and I have my battery disconnect off, the fridg will not work. Even on propane, it needs to see 12 volts from the batteries. Is this not the case with most coaches?
1968 tent trailer
1985 Jamboree 23 ft
Old 05-12-2016, 08:05 AM   #9
Most coaches when, on shore power, get the 12 volt power from the converter even if the battery disconnect is open (off).
Does other 12 volt items operate when on shore power with the disconnect open?
Gotta go campin!
Old 05-12-2016, 08:54 AM   #10
The fridge seems to be working...at least it's maintaining a consistent temperature on shoreline only. The reason I have the battery turned off is because of a defective module that keeps battery charged. I was told to pull that module off the circuit board by FR. The battery monitor is showing full charge.
Old 05-12-2016, 08:59 AM   #11
Bama Rambler...everything seems to be working on shoreline only.
Old 05-12-2016, 09:41 AM   #12
This sheds a little light on the subject. Depending on how it's wired, by pulling the charge module off the converter you could be disconnecting the 12 volt power to the fridge when on battery power. I agree that it would be weird, but I've seen some weird things in RV's before.
Gotta go campin!
Old 05-12-2016, 12:14 PM   #13
The module came off the circuit board in Battery Control Center. I haven't touched the converter in the rear of the unit.
Old 05-12-2016, 01:42 PM   #14
Sorry, I said converter, but that's not what I meant.
Gotta go campin!
Old 05-12-2016, 01:50 PM   #15
It's been 4 days with shoreline only...no noticeable downsides.
Old 05-12-2016, 07:55 PM   #16
Chief tinkerer
Gidyupgo's Avatar
Newbie here, prepping for the next trip in two days, swung by the storage lot, topped off air in the tires, turned on the propane, put the fridge on auto so it would be ready for groceries the next day, then..... turned off the battery switch on my way out.... doh! When we went to load the freezer today, had a moment of that sick feeling in the pit of my stomach, considering a two week trip using wet ice, then sigh of relief when I realized what I had done. Oh well. Live and learn.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
fridge, dometic
