Old 05-14-2015, 05:49 PM   #11
wesslvm's Avatar
Originally Posted by NCIC105 View Post
I need to pull my frige (4 door) out to replace broken water line but can't figure out how to slide it out....All I see are screws that remove the doors...
Recommend start a new thread, state model of Motorhome and make model fridge.
Wes
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 05-14-2015, 07:18 PM   #12
NCIC105's Avatar
Wes
See
Dometic Ice Maker Water Line
NCIC105 is offline   Reply With Quote
Old 05-16-2015, 12:01 AM   #13
Outlaw7's Avatar
Make sure the ice maker is plugged in and then remember that it only works when hooked to shore power, it doesn't work on propane.
Outlaw7 is offline   Reply With Quote
Old 05-29-2015, 11:28 AM   #14
I just purchased a 2015 3011ds, found the white push in/out knob, however it will neither push in or pull out. Any suggestions?
crhickenboth is offline   Reply With Quote
Old 05-29-2015, 12:38 PM   #15
I remember that I had to use more force than I thought I would have to. You may just have to put your elbow into it some more.
trnarg is offline   Reply With Quote
Old 05-29-2015, 02:39 PM   #16
mine was clearly labeled in and out ( for ice cubes). Is yours labelled the same? If so theN Just a little extra 'force'. It is a tight valve. Otherwise your valve may be a 'turn' type. Just a thought.
MMMndp is online now   Reply With Quote
Old 05-30-2015, 08:11 AM   #17
It is a push/pull valve, I had to use a lot of force to push it in.
Thanks for the advice,
Old 06-07-2015, 08:14 PM   #18
my 3010ds 2014, plug in to shore power and water, knob under stove behind draw pushed on and was getting water in tube. Still no ice, even adjust cube size behind access panel on ice maker. On level ground, what am i missing here??? anyone , any help at all any ideas?
kitejunky1 is offline   Reply With Quote
Old 06-07-2015, 08:43 PM   #19
This may be a stupid suggestion but I'll try, do you have the metal wire arm inside the ice maker pushed down? This acts as an on and off lever.
Once ice starts flowing as the ice bin fills up the wire arm will push up and cause the machine to stop making ice.
2015 Forest River Forester 3011 DS - 2007 Dodge Durango Toad
ORvideoguy is offline   Reply With Quote
Old 06-07-2015, 08:49 PM   #20
Thanks for y
dometic
