Old 05-12-2015, 06:06 AM   #1
Dometic Ice Maker Not Working
So on our first trip with our 3050, we had one issue I couldn't solve. We have the 4-door domestic refrigerator with the ice maker. I tried a number of things to get it working but the issue seems to be the water supply. I opened the back compartment above the water heater to access the fridge and turned the manual shut off valve to on. I put the arm down on the ice maker to turn it on, but no ice. Anyone had this issue? Can you point me in the right direction?
trnarg is offline   Reply With Quote
Old 05-12-2015, 06:09 AM   #2
I have the 3010DS and there is a water valve to the ice maker under the stove, behind the drawer. It's a white knob...push in to open the valve, pull out to close it. Did you check that?
jjlavin is offline   Reply With Quote
Old 05-12-2015, 06:21 AM   #3
Stove is on the other side in the 3050. I did remove the outside access panel and turn the supply to the on position, but nothing. I was tempted to remove the access panel inside below the fridge but haven't got to that yet. It would be odd to have two supply lines I would think.
Old 05-12-2015, 06:33 AM   #4
Is the Filter for the Icemaker clogged? Youroo!!
youroo is online now   Reply With Quote
Old 05-12-2015, 07:04 AM   #5
bubbles's Avatar
In the outside access panel area you did say you turned the water valve on. You did mean either pushed or pulled the shutoff valve to open it, right?
Old 05-12-2015, 12:26 PM   #6
Domestic ice maker not working
I had the same issue on my new 2014 3050s. The ice maker valve (white push in/out) is in the compartment below the fridge. Nothing in outside compartment behind fridge needs to be done.
Good luck
MMMndp is offline   Reply With Quote
Old 05-12-2015, 12:35 PM   #7
Good luck
Will try tonight and update everyone. I have not done that yet.
Old 05-12-2015, 02:12 PM   #8
Boso's Avatar
My valve is under frig in panel 2015 3050s
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 05-12-2015, 08:26 PM   #9
Success. Valve under fridge inside rv.Thanks all.
Old 05-14-2015, 03:32 PM   #10
NCIC105's Avatar
I need to pull my frige (4 door) out to replace broken water line but can't figure out how to slide it out....All I see are screws that remove the doors...
NCIC105 is offline   Reply With Quote
dometic
