Old 05-14-2015, 07:17 PM   #1
NCIC105's Avatar
Dometic Ice Maker Water Line
We have the two-door frig (four door, including freezer), with an ice maker. I need to pull the unit out to replace the plastic water line that runs to the ice maker. I cannot see any mounting screws around the frame (behind the doors) to remove so I can slide it out...Anyone completed this task?
Sunseeker 3050S - 2013
Dometic Model RM1350MIMBSX
NCIC105 is offline   Reply With Quote
Old 05-14-2015, 08:07 PM   #2
Boso's Avatar
That thing is attached somewhere with screws for safety alone
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 05-14-2015, 10:29 PM   #3
VinceU's Avatar
I had mine pulled by a shop a couple years back. There are four long screws in the the front flanges screwed into wood framing, look at Dometic books on line. It's quite heavy and bulky. A transmission jack was used to handle it.
Old 05-15-2015, 10:22 AM   #4
wesslvm's Avatar
Commonly referred to as a four door model. I would think you could replace this line without pulling the unit out of the cabinet by accessing from behind from outside.
Pleas take pics if you do pull it out!
Wes
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 05-15-2015, 03:30 PM   #5
VinceU's Avatar
Wes
I don't think you can access either water on door or ice cuber supply lines at entrance to the box as they are well above the outside door. Once the tubing begins there is no space to the wall. The water tubing will enter the box at least 2' above the access. If in a slide the upper access is blocked by the condenser finned unit.
dometic, water
