Old 08-31-2018, 01:06 PM   #1
Dometic Refrigerator Maintenance
How many folks perform the annual maintenance listed in the owners manual? It is required (as stated in item 5 of the warranty) in order to keep the warranty in force. 🤭
Kim
bayoubelle is offline   Reply With Quote
Old 08-31-2018, 04:28 PM   #2
Duckogram's Avatar
I do my own when I do the “Annual”. I probably exceed the requirements for warranty by a mile or two.
ILB ( | )
Old 09-01-2018, 07:36 PM   #3
Splitshaft's Avatar
Good luck with Dometic warranty. I just maintain my equipment as needed and don't get wrapped around the axle over warranty. I am able to make my own appliance and RV repairs when required, included replacing what is broken or defective.
Splitshaft is offline   Reply With Quote
Old 09-09-2018, 12:03 PM   #4
Kirk S's Avatar
There is annual maintenance??
Guess I should read about it.
If it involves more than keeping it clean inside and out (coils, burner, etc). I have failed in my duty.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 09-12-2018, 09:12 PM   #5
I clean out underneath and burner area, multiple times per year. Dealer does it and checks flame once a year.
AbdRahim is offline   Reply With Quote
Old 09-12-2018, 10:00 PM   #6
The warranty requires the "Preventive Maintenance" to be performed at a Dometic Authorized Service Center/Dealer at owners expense, "starting at the anniversary of his date of purchase." It's a two year warranty. So you'd only really do this once, because by the time you got to the second anniversary, the warranty would be expired.
I've never bothered. As Splitshaft says, I don't get wrapped around the axle on warranties.
2011 Traverse LT, 3.6L, FWD
dometic, maintenance, refrigerator
