Old 04-14-2018, 07:16 PM   #1
Frankie Z's Avatar
Dometic refrigerator problem
New 3010DS
Trying to get refrigerator to cool. Followed all the instructions. Tried on electric 15 amp trying now on propane.
Wondering if 2018 doesnít work on 15 amp. Larger refrigerator than last one. I included picClick image for larger version
Any suggestions?
Frankie Z is offline   Reply With Quote
Old 04-14-2018, 07:34 PM   #2
cavie's Avatar
Originally Posted by Frankie Z View Post
New 3010DS
Wondering if 2018 doesnít work on 15 amp. Larger refrigerator than last one. I included picAttachment 168282
Any suggestions?
15 amps is more than enough for any fridge.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 04-14-2018, 08:32 PM   #3
Duckogram's Avatar
Not familiar with the 4 door model but the 2 door has a switch to run on propane regardless of whether or not you are plugged in or on genny power. In the top right I see what appears to be a thermometer. If so, you have 12v power so the fridge should power up on propane. Note: There are things that need to be checked if it does not. Please post your progress.
ILB ( | )
Old 04-15-2018, 12:44 PM   #4
Frankie Z's Avatar
Found the problem gfi in bathroom was tripped.
Old 04-15-2018, 02:12 PM   #5
Duckogram's Avatar
Yup, that will cause a fridge problem all right.
ILB ( | )
refrigerator
