Old 10-24-2014, 06:32 PM   #1
DavidMPDK's Avatar
Draining fresh water tank 2015 Sunseeker 2500 tsf
I want to drain the fresh water tank and this is what I see. The Red hose is for the Hot water (as I understand it) and Blue for cold. Am I missing something here? Where is the cold water drain valve? Is there another step I am missing here? I looked everywhere I think for a valve inside the coach to no avail. Thanks for all help.
2016.5 FR3 30DS AKA "Serenity"
Searching for that perfect spot with loving Wife & 2 mini dachshunds
DavidMPDK is offline   Reply With Quote
Old 10-24-2014, 06:41 PM   #2
This looks like your (Low point) drains. Your F/W tank should have its own valve. Q,does water flow out of this Pex tube when on (Pump or City water? Youroo!!
Old 10-24-2014, 06:51 PM   #3
DavidMPDK's Avatar
No. And the fresh water tank was filled at dealer. That is why I was surprised that the tank didn't empty on it's own. That's why I thought there would be a cap on the blue to open drain.
Old 10-24-2014, 06:56 PM   #4
Have you used the H and C water system? Youroo!!
Old 10-24-2014, 07:00 PM   #5
DavidMPDK's Avatar
Yes, Both work great. Tested on city hook-ups and holding tank. No problems. Just can't figure out how to drain fresh water tank now.
Old 10-24-2014, 07:07 PM   #6
Is there a cabinet door under the bed?
biznsa is offline   Reply With Quote
Old 10-24-2014, 07:13 PM   #7
DavidMPDK's Avatar
Bisnsa yes. We looked in there and nothing really jumped out as a valve. This model has the fuse box and converter under the split bed slideout.
Old 10-24-2014, 07:14 PM   #8
Average Joe
MrJoe's Avatar
On mine, the valve for the FW drain (blue line) is located beside the water filter in a right rear outside compartment.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 10-24-2014, 07:16 PM   #9
Find the fresh water tank. You may have several points at which you can see it, like from the storage doors on either side, or from under the bed. Somewhere near the tank is a small petcock, with a line running to the tank, and another line coming out of the petcock and running into the floor. That should be the drain. Look under the rig, where that line comes out. It should be a plain line, with no cap on it. That is the fresh water tank drain. Turn the petcock, and it should start draining. Be sure to close the petcock after draining, so no insects crawl up it into your tank. Long shot but it happens.
hankpac is offline   Reply With Quote
Old 10-24-2014, 07:29 PM   #10
DavidMPDK's Avatar
MrJoe. You were right on the mark. It was right where you said. ARRGGHH...but now I have to rethink "AGAIN" my compartment usage for the forth time LOL. It seems like every time we go out I need to reorganize equipment usage into different compartments for accessibility. Thanks all for the quick responses and help. I hope that someday I will be knowledgeable enough to help someone else.
Old 10-25-2014, 06:02 AM   #11
Mike & Molly's Avatar
There is a drain valve in the same compartment as the water filer in the right side of the coach. The drains pictured are for the water lines in the coach. Used to drain the system for winterizing.
Mike & Molly is offline   Reply With Quote
Old 10-25-2014, 06:44 AM   #12
If these were low point drains, they would both have caps on them. Usually when there is a line without a cap, it is an overflow line. Maybe they used the incorrect color on the fresh water tank drain line?
Good luck,
Don
Don and Michele
3 Adult Children - 5 Grandchildren
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 10-25-2014, 08:06 AM   #13
trdutch's Avatar
Hi Dave
You found the valve for the cold in the pump/ filter compartment
The hot drain just has a cap (as shown in your pic)
Interesting read on my thread "What came out of my hot water tank"
Addresses the hot low point drain when road debris broke the cap on the hot drain and all my system water including water and all the minerals in the hot water tank siphoned out
I installed a shutoff valve on hot line right next to the valve on the cold line to prevent this problem from reoccurring
Good luck with it
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 10-25-2014, 11:28 AM   #14
DavidMPDK's Avatar
Thanks trdutch, I read that thread and a very good point. I think I will follow your lead and do the same. I hate surprises like that LOL.
500, drain, fresh water, sunseeker, tank, water, water tank
