Old 01-29-2014, 02:19 PM   #1
Average Joe
MrJoe's Avatar
Driver's side Security Light?
Has anyone added a Driver's side security light similar to the Forester? I also have OCD and can't stand having the blank in my control panel. It would also be nice when setting up at night.
I'm wondering if it would be an easy mod...
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 01-29-2014, 02:34 PM   #2
parpar1's Avatar
i am going to ride your coattails on this one. I have my saw ready.
parpar1 is offline   Reply With Quote
Old 01-29-2014, 07:21 PM   #3
I added a light just above the compartment that contains the electric and sewer on my 3170. It is hardwired into the coach but has the switch on the light. Will post a pic when it gets back from crack repair on Friday. Als added a SAT jack on the passenger side so I dont have to run the COAX through the passenger window anymore.
MountainMan43 is offline   Reply With Quote
Old 01-29-2014, 07:26 PM   #4
Average Joe
MrJoe's Avatar
Any tips for drilling into the side? It sounds easy, but just concerned about hitting something I shouldn't.
Thought about going thru right behind the control panel....maybe
Joe and Karen
Old 01-29-2014, 07:29 PM   #5
I was worried about it also so I had my service center do it. About an hour of billable time for the tech, plus parts.
Old 01-30-2014, 09:35 AM   #6
doctinker's Avatar
Rather than putting a light on the side, how about putting one inside the storage compartment aiming out, or would that be too low for your purposes?
Sent from my VS980 4G using Forest River Forums mobile app
doctinker is offline   Reply With Quote
Old 01-30-2014, 10:41 AM   #7
I have a small light in the compartment. Prefer the bigger light to be higher up so it illuminates the entire side of the RV. I can see all of the hookups as well as leaving it on when I back in so I don't run into stuff.
Old 01-30-2014, 12:13 PM   #8
Average Joe
MrJoe's Avatar
Ditto
Joe and Karen
Old 01-30-2014, 01:27 PM   #9
dcheatwood's Avatar
As you can see, my 2013 rockwood 8282ws put the work light in front of the wardrobe slide, making it useless at lighting the work area when the wardrobe slide is out. I picked up a 12v magnet-mounted light from Walmart for $5.00, screwed the lid from a tin can inside the driver side cargo door to hang it. Tapped into the 12v wire at the water heater and presto! work light. Pull it out and hang it on the heat exhaust when needed. Took about 20 minutes.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 01-30-2014, 03:00 PM   #10
doctinker's Avatar
Is this the light that you are referring to? The white component on the decals behind the slide?
light
