Old 02-23-2016, 06:56 PM   #11
I have the same Kill-a-Watt meter and it works well. The readings I get are very close to nameplate wattage for appliances I've tested, and the volt readings agree with my Fluke multimeter. Your amperage and wattage readings should be good.
You may want to put a multimeter directly on the coach batteries. Other loads on the same ciucuit such as lights will affect the reading you get with a plug-in voltmeter.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 02-23-2016, 06:59 PM   #12
2012 Solera
Don't know the device - seems a reasonable approach, but I don't understand the wattage reading and current reading discrepancy. Maybe it is reading peak current vs rms current? I just don't know. Power (watts) is volts times amps. 120 volts and .59 (rms) amps is about 70 watts. Assuming it is correctly reporting wattage, 43 watts at twelve volts would be about 3.6 amps, maybe 4 to 4.5 amps accounting for the inverter inefficiency. 20 to 25 hours in the previous discussion.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 02-23-2016, 07:12 PM   #13
I've been doing a bunch of reading online about how difficult it is to determine actual drain and remaining battery charge with the kind of cheap measuring device I am using (much less the even cheaper push-button 1/3-2/3-Full monitor that comes on the wall). I'm thinking of ordering a Trimetric 2030RV which will probably be very useful for what I want to do and do a much better job of helping me figure this out.
jeffreymhardy is offline   Reply With Quote
Old 02-23-2016, 07:36 PM   #14
AlR
Get a Trimetric 2030RV. Put mine in a few weeks ago. Best investment you can make to moniter your batteries. Guess work removed!
2013 GMC 2500 Duramax
- Ride-Rite airbags
2013 Work n Play 18EC
AlR is offline   Reply With Quote
Old 02-23-2016, 07:52 PM   #15
Yep that's what I just ordered. Seems simple enough to install.
2015 Sunseeker 3010DS
Old 02-23-2016, 08:00 PM   #16
x2x2x2x2
Nothing like it. No guesswork, you always know exactly where you stand.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 02-24-2016, 06:09 AM   #17
OK so to connect the Trimetric when I receive, as far as I understand I disconnect the one negative connection in the picture (NOT the interconnect) and connect it to the shunt...and then connect the other side of the shunt back to that negative battery terminal...so that the only path to the negative terminal is through the shunt.
But do I need to change anything on the positive side since (aside from the interconnect) I have leads coming off of both positive terminals?
https://drive.google.com/file/d/0B9v...ew?usp=sharing
Old 02-24-2016, 09:14 AM   #18
That is correct. I can't see how much headroom you have but someone on a forum made a shunt connector out of 3/4" copper pipe and it hooks directly to the negative post stud and then you just move the negative cable to the shunt output. No additional cables required.
You will need the 3 wires to the shunt (also shown) as well as a power wire for the Trimetric to any positive battery post. If you want to monitor your chassis battery, you run another small wire to it's positive post as well. The Trimetric will tell you that battery's voltage but will not monitor SOC, current in and out of that battery.
2015 335DS
Old 02-24-2016, 09:19 AM   #19
Thanks for that! That's a great idea about the shunt attaching directly to the terminal, and thanks for the photo...that will help
Old 02-24-2016, 09:25 AM   #20
In addition, think about where you want to put the unit. My Monitor panel is in the bedroom and my first idea was to put it there. Turns out it was much easier to put it right by the entrance, above where the disconnect switch is located. In retrospect, that is a much better place since I can see it from the cockpit and it does indicate things that you want to see in real time, like, engine is running...is the alternator charging the house and how far to I have to go to get back to 100%?
Trust me, you will become a SOC miser, always wanting to see that 100% number again!!!!
2015 335DS
camping, dry camping, battery
