Old 12-04-2015, 06:49 AM   #21
When I dumped the black tanks the first time, I couldn't get the valve closed afterward. I had read about this on the forum, so I stuck the hose up the dump flange and turned the water on full blast. And out comes flooring from the installation of the tanks. Sloppy! Flushed a lot and more crap (not poop) came out. No problems since. Quality control for all these very expensive products is somewhat lacking. Perhaps once you in the big A class rigs over $500k there's less of this. I'll never know...
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 12-05-2015, 11:02 PM   #22
Delco Bobby's Avatar
Wink
Although we have never pooped in this RV the previous owners may have. So I am a bit leery of getting some flying poop in my driveway. But you may be right about debris. Supposedly the tanks were supposed to be clear upon delivery to me.
I may try this when the neighbors and my family are away.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 12-06-2015, 07:26 PM   #23
I didn't get the Valterra yet but I have been concerned about any residual water in the black and grey tanks freezing. The way I normally park in my driveway the front end is lower than the rear which is how it was when I dumped the tanks.
Today I backed it in so the RV was almost level. I put a bucket under the dump pipe and pulled the cap off, a little water came out, not much. Then I pulled the grey dump valve and a few more drops came out. So after about 45 minutes maybe six drops of water. That worry is now gone.
Next I did the same with the black tank. About a gallon or a little more came out. I did notice that the rod hangs up a little while moving in and out. I didn't notice that before. We then dumped about a gallon and a half of water in the toilet and it ran right out of the pipe. I let it drip for an hour before closing the valve and replacing the cap.
I expect that I will be using the toilet over the winter so I dumped a gallon of antifreeze in the black tank via the toilet leaving a little above the valve. I didn't put any in the grey tank. The dealer put antifreeze in the sinks and shower drains.
So should I put antifreeze in the grey tank?
I was also thinking about putting some vinegar into the grey tank because there was a raunchy smell emitting from it after it drained.
Bobby
2018 Ford F-150
Old 12-06-2015, 07:42 PM   #24
Who Dares, Wins
doc73's Avatar
A bit in the gray tank won't hurt. Keeps things lubed. If the traps keep filled with AF then the stink should stay in the tanks.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 12-06-2015, 08:00 PM   #25
Will do but I have read that some rigs vanity sinks drain into the black tank. I don't know which of my facilities drain into which tank. I am probably pretty safe thinking the kitchen sink and shower drains into the grey tank.
You live close enough tour area that you were probably below freezing every night recently. We were around 27 most of last night. I waited until the afternoon before draining the tanks. I have hills on all sides so we don't get early morning sun or late afternoon sun.
2018 Ford F-150
Old 12-06-2015, 08:10 PM   #26
I dont think you will find many sinks backing into the black tank anymore unless someone modified it to do so.
In regards to the lights showing levels, mine hasnt worked since day one
2014 SunSeeker 3170DS
Ford F-450
drakethib is offline   Reply With Quote
Old 12-06-2015, 08:16 PM   #27
Who Dares, Wins
doc73's Avatar
Yeah I winterized a week or so ago. One word of advice, I'd refill the trap and toilet with AF once in a while. Keeps the stink out and keeps toilet lubed. I cannot speak to where they drain but wither way, keeping the trap filled will keep out any stink. I've never treated my gray tank. Does not mean you should not. I just do not.
2015 Chevy HD D-Max
Old 12-07-2015, 11:18 AM   #28
Thank you.
2018 Ford F-150
replacement, sunseeker
