Old 05-26-2013, 12:43 PM   #1
MKM
MKM's Avatar
E450 Driver's Seat Wiring Question
I'm getting our 2013 Sunseeker ready for several upcoming trips and noticed a wiring harness under the driver's seat that is not connected. The front passenger's seat has the same setup but it is connected. The wires come out of a 1" x 5" tube that sits along the side of the seat and is covered. There is another wire bundle that comes out of the seatbelt receptacle that I believe is for the seatbelt warning light that runs along side of this tube but is not part of the harness.
Does anybody know what it's for and if so, is it ok to connect the harness. There is a small warning label on the tube warning against checking it with an electrical power source.
Thanks,
Mark
ID:	31395   Click image for larger version
MKM is offline   Reply With Quote
Old 05-28-2013, 07:16 AM   #2
Sunseeker 2500TS owner
Mark, I have a 2014 2500TS, and from your picture your RV looks like mine, is it a 2500TS? I will look at my drivers seat and see if I can figure out what that connection is for and if it should be connected. On mine on the outside of the drivers seat there is a switch to engage the RV battery for starting the engine, not sure if that is it or not but I will look and let you know. This is my first RV so I am very new at this.
Emory
ejkkj is offline   Reply With Quote
Old 05-28-2013, 12:32 PM   #3
Mark, I looked at mine, the wiring, etc. is different than yours. I have manual seats and also have the swivel seats, so bracket is different. I did not see any wiring in that area as shown in your pictures. At bottom of the seat bracket is the wiring for the battery switch.
Sorry can't be more help.
