Old 12-05-2018, 12:19 PM   #1
E450 motor just stopped. No electrical power
I was taking our 2013 3107DS to emissions yesterday and encountered a really strange issue. After running for about 25 minutes the motor and all electrical just stopped. Nothing on the dash when turned the key and I was able to get it stopped. After sitting for a minute power came back and I was able to restart engine and get it to emissions station. On way home it continued to stop and restart after sitting for a 45-minute period.
Question to the owners of E450's out there is have anyone experienced this before? If so what did you find to fix this issue? I am taking it in for repair shop to look at and would like an idea of where to point them in advance. Thanks Patrick, 2013 Sunseeker 3170DS
aydodster is offline   Reply With Quote
Old 12-06-2018, 08:38 AM   #2
Duckogram's Avatar
In order for your chassis power to up and die you have to lose connection to both your battery and alternator. The common point that would do that is likely to be one of two basic parts. Those are your ignition switch and your main fusible link. Either one of those parts can crack and cause a power disconnect when heated then reconnect when cooled. Should not be too hard to diagnose with a meter. YMMV
ILB ( | )
Old 12-06-2018, 01:23 PM   #3
E450-wont run
thanks for the tips. I will pull out the schematics on the engine and see if I can track down the main fuse and the other items. Would be nice to fix them without a shop charge Patrick
Old 12-06-2018, 01:55 PM   #4
Sounds like a connection somewhere opening up when the vehicle warms up and gets hot.
Then after sitting and it cools down, it makes connection and away you go.
You are going to have to do some detective work with a meter and when it quits, start tracing voltage, beginning at the battery(ies)
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 12-06-2018, 03:18 PM   #5
Have you tried a diagnostics test to see if there is an error code?
Also, your rig is 5 yrs old and you may have battery cable corrosion. We had a vehicle last year that started when it chose and quit when it chose to. The battery cable was replaced, but the ground cable was not. When inspecting the ground cable, the cable itself was corroded. Once that was replaced, the vehicle started and ran without fail. Less than a $10 fix.
The most commonly overlooked problem with electrical systems is the ground.
There is no fuses with a ground and most often everything works or nothing works. And that is what you are describing.
PenJoe is offline   Reply With Quote
Old 12-06-2018, 03:41 PM   #6
all of them seem to have what to start with.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
Old 12-06-2018, 04:41 PM   #7
Garrette's Avatar
I have a 2014 Sunseeker 3170 DS. Please post the cause and correction when problem is solved. Thank you.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 12-06-2018, 04:47 PM   #8
2007 WildCat 32QBBS
05CrewDually's Avatar
First thing to check is battery connections. Next is to have the batts load tested.
05CrewDually is offline   Reply With Quote
Old 12-06-2018, 06:07 PM   #9
X 2 Also probably the cheapest place to start, easy do it yourself.
2017 FR3 28 DS
cariboo camper is offline   Reply With Quote
Old 12-06-2018, 06:43 PM   #10
Total Loss's Avatar
Loose or corroded ground would be my first guess.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
electric, electrical, power
