Originally Posted by bubbles
That's the way to do it. Bypass the protective device with power; what's the worse that can happen. Don't you have a meter to check the motor?
I don't think there is a protective device at all going to a power awning. Just 12VDC power and a switch. I was just rewired the brand new camper.
Could just be a bad switch or loose connection. Wife and I just traded the Flagstaff 25KS for the Catalina 253 RKS and as I was tearing apart the new camper I found several crimp ends very loose and was able to just pull right off. I usually fix as I am installing my upgrades.
Here is a pic of the dimmer I installed for the awning LED lights. Right behind that panel is the switch for the lights and the power awning switch.
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
