Forest River Forums
Sunline User Photos
Old 07-24-2011, 07:35 AM   #11
kbrown1075's Avatar
Mine is working fine so far!
Kirk, KN1B
2011 Flagstaff 26RLS
2000 GMC Sierra 1500
kbrown1075 is offline   Reply With Quote
Old 07-31-2011, 07:48 AM   #12
funseeker's Avatar
I've had awning problems one time on my 2010 Sunseeker 3120. It would not unfold. I cycles the switch several times. Maybe a loose connection. Also, when you tilt the awning to one side for rain to roll off, make sure it is not on the motor/electrical side.
funseeker is offline   Reply With Quote
Old 09-07-2011, 08:48 PM   #13
Our 2010 Sunseeker 3100SS awning is acting up also. Sometimes it does not want to retract without some muscle help. I think the spring needs rewound. Has anyone done this before?
niedobry1 is offline   Reply With Quote
Old 09-08-2011, 05:52 AM   #14
I am starting to think that the problem is the awning is out of line.I have noticed that the awning is after moving to one side more than the other and I think this is causing the awning to jam as it is rolling up.I've tried everything to pull it back so that it would be even on both ends but no luck.I guess I will have to take it in to the dealer...
gucci is offline   Reply With Quote
Old 09-08-2011, 06:43 AM   #15
Send a message via Skype™ to stevo
Two years and two motors{chinese} easy install,recommend two people as a safer install!Motors will easily wind awning in without help.
stevo is offline   Reply With Quote
Old 03-26-2012, 08:13 PM   #16
funseeker's Avatar
I have a sunseeker 3120 with awning issues when in key west I cycled the switch several times to get it to work. I need to check the connector for corrosion. I suggest when it rains, tilt the awning lower on the opposite side of the motor/connector to prevent water from getting in the motor/connector.
Old 03-26-2012, 08:45 PM   #17
Steve09's Avatar
Hey, does the motor end on these electric awnings still have to be locked to be removed ? Our camper is 2yrs old ,no problems yet,I was thinking about installing this 10 ft section of stainless inside to remove a little bow that I have in the awning pole,,,(it has always had a slight bow) check this out RV Awning Repair | MegaX57
2009 Salem La 292FKDS--7600 lbs
2004 F-150 5.4 Auto FX4 3.73 Gears with Factory Tow Pkg,36 Gal Tank,92,000 miles,Equalizer Hitch 10000 lb Bars MBRP 3in Cat-Back Exhaust SI/SO
24 Days camped so far in 09
35 Days camped so far in 10
24 Days so far in 11
Steve09 is offline   Reply With Quote
Old 03-26-2012, 09:21 PM   #18
Lou Amadio
herk7769's Avatar
Steve,
I have got to say that that repair idea is very neat. It is going in my bag of tricks and it may help someone (maybe even me!) one day.
Here is the manual on the electric awning.
Not much in there, but good luck.
File Type: pdf Dometic 9100 Power Awning User Guide.pdf (404.7 KB, 13 views)
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is offline   Reply With Quote
Old 03-26-2012, 10:21 PM   #19
dunnnc's Avatar
This might be of some benefit if you are going to take the motor & spring off the tube.
Days camped in 2011-71
Days camped in 2012-53 as of 07May12
2012 Flagstaff 8528RKWS
2005 Silverado 1500 Ext. Cab
dunnnc is online now   Reply With Quote
Old 03-27-2012, 08:55 AM   #20
Steve09's Avatar
Thanks alot !!,,looks neat hope it works ,,I'll ley ya know.
» Online Users: 590
102 members and 488 guests
0721SSROO, 09grizzly1, 2007Rockwood2601, 4tonns, austincpr, Badie, bean, Bearcat55, Bigjimt, bignugget, BlakeB, bob34787, Bob_Loblaw, bouldercamper, brandon0214, brookside, Buster1281, Cascade Bob, CHD Dad, chevy02, chof16, darkcloud, dasimser, deerslayer, DGrissom, dimurrrw, djorgensen3, DonG, donn, dsdaniels, dunnnc, Emptypockets, Flying dutchman, frankm, Ga.Lineman, Great Horned Owl, gredmer, HAARubicon, HemiCab, Hob, HockeyDad217, Iggy, Jack67, jaxfl, jdefeo1, JDWeir, Jeep4Two, JeffK, jes520, joy-rick, kamp k, ldmcmahan, LeadPoop, LFugate, Linnemj, maggiek, mckirby50, micalo, mike1329, milw156, mlhalter, mn_guy, mrdon003, mtnguy, Pa-cj5, ParrotHead, parrott34, Patrick29, pchrcane65, pg_rider, pixleys, punkaccountant, rdwin, realebill, rgmiller32, rld_42, ronhanson, RV Guy, RV Van, sail2liv, schrederman, Skippkon, snowbrid, Stank Bait, stevem4134, superk1035, tdavis300, tedstr, Tee, terryh, TheFlagGang5, TheSasks, toclark491, tonybab, travyp, Triguy, vp22er, VTX Al, Waterfowlwarrior, weiman1983, Wiscampsin, woodsman
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
