Old 07-09-2013, 08:08 PM   #11
Garrette's Avatar
Loosen the black knobs. May be binding.
Garrette is offline   Reply With Quote
Old 07-09-2013, 08:19 PM   #12
OP here - They are loose. Generally about a quarter to half turn less than just loose (if that makes any sense).
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 07-09-2013, 08:21 PM   #13
Mine does it too and my trailer is only 6 weeks old. I guess I'm gonna have to look into it now. Btw I have a 2013 stealth 2812
Cacooze is offline   Reply With Quote
Old 07-09-2013, 08:22 PM   #14
PHS79's Avatar
Mine are loose too, probably about 2 full turns
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 07-09-2013, 08:27 PM   #15
Herk7769's Avatar
Originally Posted by OldCoot View Post
Make sure the material is centered on the tube and lube all the pivot points on the arms including the gas strut pivots. Look for scuff marks on the support channel on the trailer and see if there is a matching scuff mark on the movable arm. Might have to bend the arm very slightly.
Neil is right on. The awning material only needs to slide about 1/4 inch to twist the arms enough to bind on opening or closing. Wind flapping from the other direction can actually "fix" this problem; only to have it recur again.
The solution is to get on a ladder and "flap" the awning while tugging it until it retracts with no binding; then pop rivet it in place like so...
HAM CALLSIGN - KC3FFW
Old 07-28-2013, 09:05 PM   #16
PHS79's Avatar
Today I looked into this issue a little harder since I had time to. The arms of the awning are catching on the bracket that is bolted to the outside of the camper. For me it is the leading edge, the backside there is a 1/4" gap between the arm and the mounting bracket. I took some measurements of the awning to the mounting brackets and also the awning on the tube. It looked like there was some sort of a spacer in the awning tube so that the awning couldn't slide towards the front of the camper anymore than it already was. Then I centered the awning up according to the measurements, it was about 3/16 towards the front of the camper, I retracted the awning it did the same thing. So I slide the awning another 1/4" towards the rear of the camper, I retracted it again and it still did the same thing.
Should I try and slide the awning on the tube more towards the rear? I just don't want to go too much and screw something up. Any suggestions on what to do?
nights camped:
Old 07-28-2013, 09:13 PM   #17
The way I do it is extend the awning out and shift the awning material on the tube until it is the same distance from both end caps. Over the time it has been off centered, it could have stretched the material a little. If it is still hitting on the front, have someone hold that arm very lightly and retract it. An easy way is to loop a rope over the tube and hold it to put a little tension on the material while you retract it.
Old 07-28-2013, 09:25 PM   #18
Road-King's Avatar
I tried that on my camper, then I realized the awning fabric was not evenly spaced from the support arms up at the gutter where it attaches to the camper... So I made the measurements from the support arms to the awning fabric the same at the top and bottom when the awning is out.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 07-28-2013, 09:33 PM   #19
That works too. I always just centered it at both places. It takes a lot more work as you have to remove the screw at each end of the awning at the trailer.
Old 07-28-2013, 09:51 PM   #20
PHS79's Avatar
Since mine was off center to the front 3/16" and it is now 1/4" off center to the rear maybe sitting like that for the week will help stretch the material back a bit.
The tube seems to come up to the camper at the same time both front and rear. What is happening is the U of the awning arm is hanging up on the lower front edge of the wall bracket, so right now the U arm is tight on the front edge and 1/4 gap on the back side.
Just wondering how holding back on the tube would help correct my problem?
On a different note: I had someone on a different RV site email me about the awning poles, wondering who made them and were they could get a set. They were disappointed when I told them that the "business" closed its doors...
nights camped:
