Old 05-17-2015, 09:15 PM   #1
Electric Hot Water Heater, is it always on in my 3070
I have a switch that cuts on the propane hot water heater, but i cant find one for the electric
seems like it is on if plugged in, any ideas?
2014 SunSeeker 3170DS
Ford F-450
drakethib is offline   Reply With Quote
Old 05-17-2015, 09:18 PM   #2
open the cover outside on water heater look for a small usually black rocker type switch sure its full of water before switching to electric
sparkync1 is offline   Reply With Quote
Old 05-17-2015, 09:19 PM   #3
Flybob's Avatar
If it is a suburban, it is in the lower left corner of the WH. You need to open the outside access door and look in lower left hand corner on unit. Should be a small black rocker switch. May be behind wires.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 05-17-2015, 09:59 PM   #4
wmtire's Avatar
Here you go, with pics.
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
I've just ordered a chicken and an egg from Amazon.... I will keep you posted.
Old 05-17-2015, 10:27 PM   #5
BooBoo23's Avatar
When it comes time to winterize and you drain your water tank make sure you turn that switch off or else you will be replacing the heating element.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23
Camped 2015 - 47
Camped 2016 - 51 done - 6 more planned so far
BooBoo23 is offline   Reply With Quote
Old 05-18-2015, 07:29 AM   #6
Before I wired in a switch with light, I found it easier to turn it off at the breaker. In your breaker panel (under bed) one of the breakers will (should be) labeled water heater ( might abbreviate it to "HW")
2011 Sunseeker 3170DS - 30,000 miles explored
funfinder5 is online now   Reply With Quote
Old 05-18-2015, 08:06 PM   #7
The switch was outside on the hot water heater. everytime I have plugged the Coach in it was on even in storage
Apparently the people who owned it before me never bothered to turn it off nor did the dealer who did the 200 point inspection which they say cost them about $2000.00 to do.
Thanks for all of the help folks !
Ford F-450
electric, heater, hot water, water, water heater
