Old 05-16-2015, 06:55 AM   #1
Sunnyfun's Avatar
Electric Socket Under Kitchen Cabinet in Sunseeker 3050
Anyone have any solutions for the electric socket under overhead cabinet over sink on right side ,very awkward. Appliance cords do not reach, have to plug in surge and bring across window area and not liking the look and feel it is not safe so close to water faucet. Has anyone come up with better solution, are installed new socket on left of cabinet. Love my kitchen, but, evidently someone wasn't thinking when they designed where to install the socket. Thanks for any solutions !
Sunnyfun is offline   Reply With Quote
Old 05-16-2015, 08:32 AM   #2
Plug
I just plugged a power strip in and velcroed it to wall under the plug on counter. Wire tied wire to window trim.
J. V.
2015 Sunseeker 3050s
15 Years Full Timing
Now own Sticks and Bricks
J. V. is offline   Reply With Quote
Old 05-16-2015, 08:34 AM   #3
Any reason why it can't be relocated? You could put a faceplate over the old location to hide the hole.
biznsa is offline   Reply With Quote
Old 05-16-2015, 10:29 AM   #4
Sunnyfun's Avatar
Yes, I was thinking about the Velcro , but, just don't like the look of the power strip. I was also thinking about getting another outlet installed on the left underside of cabinet. Has anyone had that done. We would have to have someone do it, since my husband doesn't do that sort of thing. Wondering if so, can it be done and how much cost. Thanks biznsa and J.V. for your thoughts.
Old 05-16-2015, 11:19 AM   #5
They install the outlet into the upper cabinet because you can't put an outlet into the exterior wall. You could easily mount another outlet wired in series with an existing outlet to another area of your under counter cabinets. Don't worry about danger of shock from the over cabinet outlet it should be GFCI protected.
Handydc is offline   Reply With Quote
Old 05-16-2015, 04:37 PM   #6
Retired
We have the sunseeker also and have our coffee pot there next to the sink. We put that putty on the bottom of the coffee maker and it stays there. We have over 17,000 miles on our sunseeker and traveled up & down mountains and it has not moved. If we wanted to move it we just use a little force and pick it up and then to put it back in that spot take the old putty off and put new putty down. The putty is made by Duck and is called poster putty at Walmart or Lowes. The coffee maker's cord is short and does not lay on the counter. My sister had used the putty for that purpose and told me about it.
tennlady is offline   Reply With Quote
Old 05-16-2015, 06:38 PM   #7
X2. When we get back home next week, we're going to check with an electrician to see about having an outlet installed on the left underside of that cabinet. It's definitely inconvenient where it is now as no appliance fits to the right of the trash opening.
SkipnTerri is offline   Reply With Quote
Old 05-16-2015, 07:24 PM   #8
Sunnyfun's Avatar
Sklpn Terri, I totally agree, not sure what they were thinking when they put it on the right side. Our 3050 is a 2014, I think I saw where the 2015 has it on the left. I will probably end up with doing what you are going to do. That is the only thing I don't like in our Sunseeker, so I guess that's not too bad.
Old 05-16-2015, 07:39 PM   #9
Sunnyfun's Avatar
Thanks tennlady, that sounds like I could use the putty to keep the surge socket in place too.
Old 05-17-2015, 07:17 AM   #10
cpaulsen's Avatar
Have an outlet like that also....I just bought another outlet...box and cover and wired the new on in by splicing into the wires of the original box. Moved it a lot closer to the coffee makers. The original one is still functional. I use it for charging the cell phones and my cordless drill.
cpaulsen is offline   Reply With Quote
305, electric, sunseeker
