The light on the microwave is your proof of AC power. (Also anything that works in a plug socket.) You will be fine on 15 amp power as long as you don't run the A/C or too many other things at once. Just remember that you are plugged into one 15 amp socket for the whole RV, so act accordingly just like you do with one plug socket at home. The microwave works in a plug socket, as does a small space heater - just as each would at home. But if you run both at once you may blow the circuit breaker in the home line - just as would happen in one socket in the house.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
