There should be some 12 volt wiring routed to the slideout from the power distribution panel. You can follow that with the 120 volt wiring. Access into the walls at the location you need may be a bit of a problem though. You'll need to use some pretty flexible cable to go from the stationary point across the movable point. You'll also need to support it well to the existing cable support or run a new cable support across the slide bottom. SO cable should work for that. You'll also need to add a breaker in the power panel if there's space for it.
The penetrations and routing needs to be done correctly to make it as safe as it can be, so if you're not familiar with that type of electrical work, you may want to enlist the help of someone that is.
Gotta go campin!
