Old 02-21-2016, 04:48 PM   #11
Thank you.
Kevin & Judy is offline   Reply With Quote
Old 02-21-2016, 05:54 PM   #12
Here's the Ground Current Test I designed. As you can see it's just a standard automotive 12-volt test light being used "backwards". So instead of grounding the clip and using the probe to look for 12 volts DC. You put the clip on the positive battery post and use the probe to check for ground on your shore power cord. This performs a fairly complicated test very simply. Since it pushes an ampere or two of current through the entire ground path, the light bulb will be dim or not glow at all if you have a loose EGC connection anywhere in your RV's electrical system.
You should start the test on the shore power line itself, then add any adapters or extension cords one at a time, checking each of them for continued ground continuity. Plus you can flex each connection while watching the light to make sure it doesn't blink. I bought my tester with a little alligator clip on the nose for about $10, and it works great for this test.
Note that this test is done with your RV's shore power cord DISCONNECTED from any 120-volt AC power. That's makes this perfectly safe and shock-free, even if you do find an open ground.
jmsokol is offline   Reply With Quote
Old 03-15-2016, 01:47 PM   #13
Finally got back to the campground, figured out the problem, Some goofy neighbor had tied an old extension cord to bottom of my bumper to keep it out of the dirt, It was a bit bare on one side causing the problem, Promptly removed it and delivered to his front door, Thanks for all the help.
Old 03-15-2016, 04:04 PM   #14
Who Dares, Wins
doc73's Avatar
Wow that is scary..
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 03-15-2016, 04:11 PM   #15
Mr. Dan's Avatar
We normally hear about various electrical/electronic testers on this forum. What we also need is a "Goofy Neighbor Tester" (a GNT).
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 03-15-2016, 04:22 PM   #16
Who Dares, Wins
doc73's Avatar
Think I'd want a new neighbor as well...
2015 ChevyHD D-Max
Old 03-15-2016, 04:37 PM   #17
Ford Idaho's Avatar
Did you super glue the ends together first?
Old 03-16-2016, 07:34 AM   #18
wish i had thought of that. LMAO
Old 03-16-2016, 08:35 AM   #19
SeaDog's Avatar
Sometimes simple is best.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-16-2016, 08:39 AM   #20
Mr. Dan's Avatar
I believe a good lesson may have come out of this - maybe an addendum to our procedures.
"If you touch your bumper and it shocks you, look on the other end of said bumper and see if someone has attached an extension cord to it."
This procedure addendum might save a life!
electric, electrical
