Old 02-21-2016, 10:35 AM   #1
Electrical shock
Was doing some maintaince on our motorhome yesterday Sunseeker 3010DSF.
I had leaned down to pick something up off the ground and put my had on the corner of the rear bumper and got a slight jolt . Thought it may just be i had hit a nerve in my hand i checked it again and yes getting a slight jolt. It is plugged in to a 30 amp with progressive dynamics surg protector and can not fugure out why its doing this, Nothing on the readout of the surge. All shows ok. Any thoughts ?
Kevin & Judy is offline   Reply With Quote
Old 02-21-2016, 10:59 AM   #2
KyDan's Avatar
You should not ever feel a shock when touching your RV. I advise getting the site maintenance to check for proper ground at the plug. Also take a voltage reading between your RV and ground at the power post-- should be zero.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 02-21-2016, 11:04 AM   #3
The plug has been checked, Was there when the electrician pulled it and checked. It is correct, If this was the case wouldnt the surg guard detect it, The read out show all is fine everything workg correctly.
Old 02-21-2016, 11:25 AM   #4
VinceU's Avatar
Somewhere there is a reverse polarity in the supply, at the pedestal, in the RV cord or recept. They sell plug in testers that locate the fault. Now you have the live side of the 110 volt connected to the "safe side" of the circuits. You as ground become the path of electricity on grass or soil. If your not confortable with repairs get a qualified, the situ can be harmful.
Old 02-21-2016, 11:49 AM   #5
wmtire's Avatar
Kevin and Judy, please read this sticky that we made from a fellow member who is the de facto expert on your situation. Mike Sokol has a great website dedicated to this, and is one heckuva nice guy, with all the time he spends with members here trying to help them determine what is wrong with their RV's and this dangerous situation.
I get shocked when touching RV
As always, I will send him a PM informing him of your problems, but please read the above link IN IT'S ENTIRETY with video , as well as the links to his website, where he explains how to test for this situation.
Your situation can be deadly and needs to be fixed ASAP.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 02-21-2016, 01:05 PM   #6
RV Electricity Expert
jmsokol's Avatar
All true. But realize that most site maintenance guys really don't know how to check for proper grounds. So let's review the basics.
1) If you have a proper, lo resistance ground connection (called the EGC or Equipment Grounding Conductor) connected from the frame of the RV all the way to the campground service panel's neutral-ground bonding point, then it's impossible for any voltage to exist on the frame/skin of your RV. Rusted hot water heater elements won't cause a hot skin voltage if your EGC ground path is good. Nor will reversed polarity of the Hot (black) and Neutral (white) wires in the outlet. In order for there to be a hot-skin voltage condition, there MUST be a failure in the EGC ground path.
2) The EGC ground can fail in two basic ways. Either there's a rusty or loose connection in a plug somewhere, a loose ground-bonding screw inside of your RV's breaker panel, or something really scary has happened to the ground wire in the pedestal due to a mis-wiring condition I call a RPBG (for Reverse Polarity Bootleg Ground).
3) In the first EGC ground failure in #2 above, the loose or broken ground wire will allow any leakage currents inside your RV to create a voltage on the skin of the RV. This can either have a little shock current available, or a LOT of shock current available. You can't tell without sophisticated testing, but know that ANY more than 2 or 3 volts between the frame of the RV and the earth is an indication that the EGC ground has failed somehow.
4) In the second EGC ground failure in #2 above, something I've discovered and named a Reverse Polarity Bootleg Ground has been created by an electrician trying to run a grounded outlet without a ground wire. It will test as perfectly OK using all standard tests, including things like the Progressive Industries PMS Surge Guard. See my latest article on it at http://livesoundadvice.com/noshockzo...-rpbg-dangers/
5) Also know that products such as the PI Surge Guard can't detect a broken ground downstream of themselves. So if you use a portable Surge Guard plugged into the campground pedestal, it can't alert you to a broken ground wire between the Surge Guard and your RV. So you could sill have a broke EGC ground wire in the extension cord plugging into your RV, or even a loose ground-bonding screw inside of your RV's circuit breaker panel.
6) The easiest way to test for a hot-skin voltage is with a NCVT (Non Contact Voltage Tester) such as a Fluke VoltAlert or Klein NCVT-1. See my video at
7) The gold standard test for hot-skin voltage is using a DMM (Digital Multi-Meter) between the frame of the RV, and a ground rod. In this case, a long screwdriver stuck in the damp earth will suffice. You should not measure more than 2 or 3 volts AC between the frame of the RV and the earth itself.
Do some troubleshooting and let me know what you find out. But don't believe anyone at the campground who tells you that feeling a shock is normal. It's not normal and an indicator that your RV's EGC ground path has failed.
jmsokol is offline   Reply With Quote
Old 02-21-2016, 05:11 PM   #7
Certified master electrician installed and re.checked. Not a maintaince man, Have pluged in to other sites, not at the same park, and the problem is still there, He points to a problem in the coach, have had the coach 2 yrs and never had the problem, Surg guard is hard wired in the system, Will perform some other checks in the next few days, Thanks for all the ideas,
Old 02-21-2016, 05:21 PM   #8
jmsokol's Avatar
If all of that is true, then you must have a high-resistance connection feeding or inside the RV's circuit breaker panel. Check to make sure the G-N bonding screw hasn't vibrated loose (seen that a few times), and that you have a low-resistance connection on any connector feeding the service panel.
Also, I had an RV last year with a factory run wire that was pinched between the floor and a crossbeam. After 2 years it rubbed through the insulation and made a line-to-frame short circuit. Because the ground wire was also trapped, it burned through. So the incoming hot wire from the pedestal was short circuited to the frame of the RV, while the ground wire of the RV was burned open. This effectively created a natural RPBG that was AFTER the Progressive Industries Surge Protector. So the Surge Protector knew nothing about it. I've designed a really simple ground fault impedance tester that costs about $10 to build and is the best thing I've ever seen to check for proper low-resistance EGC Ground paths in an RV. If you guys like, I'll post plans for it here.
When it comes to electricity, assume nothing.
Old 02-21-2016, 05:23 PM   #9
wmtire's Avatar
I would like that Mike, would you care if we also put it in our library for downloads?
Old 02-21-2016, 05:32 PM   #10
jmsokol's Avatar
That will be fine. I'll find the plans tonight and post them here. The design is so dumb-simple, it's brilliant. Basically, my ground current tester is one-half of something called a Kelvin Bridge, which I used in the 80s' to measure resistors for the nuclear missile guidance systems we were building. (No kidding).
electric, electrical
