Old 03-04-2014, 10:12 PM   #1
Engine oil for Ford 2014 Sunseeker
Just wondering how many of you use synthetic oil. I'm due for my first oil change and would like to start out using synthetic. Thanks for all the great advice.
Bednarski1 is offline   Reply With Quote
Old 03-05-2014, 12:03 AM   #2
SKnight's Avatar
I was a mechanic for 17 years, I also have Mobil 1 in everything I own, from the diesel truck to the wifes van to my motorcycle, lawnmower, generator and weedeater.
Synthetic is pretty amazing, it's slipperier than conventional oil, thus more efficient, lubes better, doesn't break down as easily.
I'm a fan and I'm a cheapskate. You can extend your oil change interval also. Opinions vary, but a 50% increase is common.
Old 03-05-2014, 12:59 AM   #3
If you are going to drive more than 15K per year go for the syn if not use dyno. You won't wear out the syn but you may time it out. Dyno(saur) oil has progressed so far over the years you will have little advantage unless you are racking up the hours. I agree that syn is a better oil but I don't agree that it is a better value unless the application is nearly continuous. I have some credentials in this area but do as you wish.
Timtation is offline   Reply With Quote
Old 03-05-2014, 04:34 AM   #4
What does the manufacturer recommend? When I took my Chevy in for the first oil change, I was surprised that they said it had to be synthetic blend at a minimum. I went with full synthetic.
My brother is a retired engineer from Ford. He worked in oil systems for the last several years of his career. Has a patent on a true oil monitoring system (which Ford later sold to Mercedes instead of implementing it on their own vehicles). The chief advantage of synthetic oil is the smaller molecule size that lubricates better when the engine is cold. Once conventional oil warms up, it is just as good. But that critical time when the engine is still cold is when synthetic is best. He found that a blend was just as effective at that time as full synthetic. But the cost difference isn't that much, so I use full synthetic.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 03-05-2014, 05:47 AM   #5
RvBill3 is right on, start up is when the most wear on the engine will happen.
Lets face these RV's will sit for weeks at a time, that's when you want the best protection, full synthetic.
2014 Silverback 33RL
2013 F350 DRW 6.7
jimmac28 is offline   Reply With Quote
Old 03-05-2014, 01:24 PM   #6
Mike & Molly's Avatar
Syn - All The Way
I use Amsoil Syn in all my machines.
Most think it's to expensive, but in reality, it is cheaper than dino oil.
You get: increased gas mileage - longer engine life/less wear, better heat protection, Flows at -25 degrees, extends oil changes up to 15,000 miles rather than 3,000,. Check out the Amsoil web site & see for yourself.
Good Luck
Mike & Molly is offline   Reply With Quote
Old 03-05-2014, 04:37 PM   #7
Retired on the weekends
The RB's Avatar
As a side note, what weight of synthetic is everyone using?
2008 Sunseeker 3120 DS
CLICK HERE FOR THE PACIFIC NORTHWEST RV GROUP
The RB is offline   Reply With Quote
Old 03-05-2014, 05:32 PM   #8
SKnight's Avatar
I go with factory spec especially while under warranty.
Old 03-05-2014, 05:38 PM   #9
Phat Phrog Stunt Crew
awwall's Avatar
I use Ford 5W20 syn-blend as recommended by Ford. I think that is pretty much their standard these days. With the RV, I own 3 Fords and use this on all 3.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 03-05-2014, 07:39 PM   #10
5w 30
sunseeker
