Old 02-15-2015, 12:46 PM   #1
Engine Size
How do I determine the exact size motor in my 2012 Sunseeker 2450S? It is a Ford chassis. The sticker near the radiator says it could be 4.6L (highly doubt this), 5.4L (doubt this too) or 6.8L (think this is it). I thought the Ford would have a V-10 badge on it if it was the 6.8L, but there isn't one. I bought it used so there isn't a lot of documentation with it.
The reason I want to know is so I can determine how large of a vehicle I can pull behind it. Most likely the vehicle would be a 2 door or 4 door Jeep Wrangler.
2015 Jeep Wrangler Toad
SilverSunseeker is offline   Reply With Quote
Old 02-15-2015, 12:49 PM   #2
I would go to a Ford dealer with the VIN number and have them check it out for you.
micalo is offline   Reply With Quote
Old 02-15-2015, 12:56 PM   #3
Mojojojo's Avatar
Unless you want to crawl around the engine looking for the block stamp, if it's a v 10 just count the plug wires or (coil packs if that's what they use).
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 02-15-2015, 01:02 PM   #4
GreenImp's Avatar
Send a message via MSN to GreenImp
I don't know what information is coded within Fords VIN's, but this may save you a trip to the Ford Stealership...
VIN Decoder | fleet.ford.com
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 02-15-2015, 01:03 PM   #5
If the eighth digit in the vin is a "S" you have the 6.8l V10
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 02-15-2015, 01:04 PM   #6
Mojojojo's Avatar
I believe it would also have ten spark plugs.
Old 02-15-2015, 01:08 PM   #7
Yes it would have ten plugs but a LOT!! easier to check vin then start counting plugs Unless your into that thing!
2014 Forester 3051s
2012 Sonic toad
Old 02-15-2015, 01:12 PM   #8
Mojojojo's Avatar
I usually have grease stains on my fingers and clothes so one could say I'm into that sort of things.but you only have to count 5 on one side so you only need to use one hand right?
Old 02-15-2015, 01:21 PM   #9
I have seen the 5.4L in our motorhomes. Just the small class C's.
markangie24 is offline   Reply With Quote
Old 02-15-2015, 01:40 PM   #10
rsscully's Avatar
Type the vin number off your door into this. It will give you the window sticker for your chassis. Just make sure to use the Ford vin and not the forest river one.
http://researchmaniacs.com/VIN-Numbe...cker/Ford.html
rsscully is offline   Reply With Quote
