Old 04-26-2015, 09:25 PM   #1
Exit window 3050sf
Hi, Question what happens when you open the rear window? Is it hinged at the top or fall to the ground? It says exit only.
13larry is offline   Reply With Quote
Old 04-26-2015, 09:30 PM   #2
Hinged at the top. it won't fall out.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-26-2015, 09:53 PM   #3
tmhyer's Avatar
You need to open it so if there is an emergency, it wont be your first time opening it.
tmhyer is offline   Reply With Quote
Old 04-30-2015, 09:12 PM   #4
wesslvm's Avatar
I put a screen on mine, held on by magnets, so I can prop it open and now I get more fresh air.
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 04-30-2015, 09:16 PM   #5
Screen is great idea. Window is steel so magnets work? Did you get a custom screen or ?? Please give details. This is exactly what we were looking for. Thanks Larry
Old 05-01-2015, 09:03 AM   #6
wesslvm's Avatar
I bought sudden and magnets at hardware store. I used epoxy to mount magnets along frame. I cut screen to size.
I also used small binder clips to hold along vertical sections with the magnets along top and bottom.
I can take pics this weekend.
Wes
Honda CRV (TOAD)
Old 05-01-2015, 09:42 AM   #7
thanks WES photos would be great, what do you use to keep it open? Stick from outside?
Old 05-01-2015, 11:06 AM   #8
wesslvm's Avatar
Larry, combination of pole and bungee cord from outside
Honda CRV (TOAD)
Old 05-01-2015, 11:08 AM   #9
wesslvm's Avatar
As Brian has pointed out, need to make sure you don't modify in any way that would cause the exit path to be blocked as a safety exit path.
Honda CRV (TOAD)
Old 05-02-2015, 05:34 PM   #10
wesslvm's Avatar
Took some pics
ID:	75928   Click image for larger version
ID:	75929   Click image for larger version
Honda CRV (TOAD)
305, 3050s
