Old 01-06-2018, 06:35 PM   #1
Extend a stay?
Has anyone installed an extend a stay (propane tee) on a Sunseeker? When I asked our dealer he said we didn't want to do that. No reasons given.
Thanks,,
Shirley
David and Shirley
2017 Sunseeker 3010DS
shirleyj62 is offline   Reply With Quote
Old 01-06-2018, 06:47 PM   #2
I ordered one on Friday. Have not received it yet. I do not see any reason why it would not work on a sunseeker.
Retired Chief USN
2017 Sunseeker GTS 2800
charles l is offline   Reply With Quote
Old 01-06-2018, 07:08 PM   #3
RedLdr1's Avatar
I plan to add one this coming season. When I discussed it with my dealer they did not have any negative comments regarding it.....
Wayne and Christine
2020 Sunseeker MBS 2400Q On Order
RedLdr1 is offline   Reply With Quote
Old 01-06-2018, 07:17 PM   #4
sgtlm17's Avatar
I put one on my Forester and even did a video on it. I use it every trip with a 20 lb lpg tank. I also connect my BBQ to it. One of my best upgrades. Works flawlessly.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 01-06-2018, 10:46 PM   #5
If your video is on YOUTUBE, can you please post a link to it?
David and Shirley
Old 01-06-2018, 11:00 PM   #6
Just put one on our 2017 2800qs it works great. It is easier to refill a tank than to have to totally decamp and refill on board tank then reset up.
Tom C 47 is offline   Reply With Quote
Old 01-07-2018, 03:05 AM   #7
sgtlm17's Avatar
https://youtu.be/PcDcIeohpNQ
2011 Jeep JK Toad
Old 01-07-2018, 01:01 PM   #8
DaGrinch's Avatar
Ditto.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 01-07-2018, 04:33 PM   #9
We paid a mobile rv repair to install ours as we were in a rv park aand out of propane. Looks to be very easy, just do not our tighten the brass fittings and be sure to use a leak tester on all fittings. Our repair guy found a leak at the distance valve that he had not even touched. I was watching and he checked for leaks before starting and after the install.
Old 01-07-2018, 06:44 PM   #10
Garrette's Avatar
Extend a stay?
Very easy. Even though I have winterized, we like to keep a little heat. Using extend-a-stay and 20lb BBQ tanks as I type this. Just check for gas leaks and if you used pipe tape, get tape for gas.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
