Old 01-22-2013, 05:20 PM   #11
GM
bclemens's Avatar
My kids look at tube tv's with disgust. Like it's some deformed animal.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 01-22-2013, 06:39 PM   #12
Grizzlygibbs's Avatar
Originally Posted by paulmlac View Post
Gotta say seeing the phrase "old style LCD TV's" is funny!!!
No kidding right! This last "Black Friday" I bought my very first LCD from an online retailer BH Photo at an excellent shipped price. I can't believe I have waited for so long to do it.
I plan to remove the LCD from my TT as well during the winter.
Grizzlygibbs is offline   Reply With Quote
Old 01-22-2013, 07:41 PM   #13
Herk7769's Avatar
Originally Posted by bclemens View Post
Just to clarify. LED TV's and LCD TV's are BOTH LCD screen TV's.
The difference is LED TV's are "backlit" using LED's. Whereas old style LCD TV's use Cold Cathode Fluorescent Lamps. Screens are the same...lighting is different. Most modern day LCD's are rated for pretty cold temps.
Yep, just leave the TVs in unless temps will go below -30 degrees (without wind chill). Wind chill not applicable since TVs won't be in the wind and have no skin to speak of.
HAM CALLSIGN - KC3FFW
Old 01-22-2013, 10:09 PM   #14
DDC
DDC's Avatar
Think I would just take the toad home it would save you a lot of worry and the bother of winterizing, and good luck with the freezing problems, I always turn the water off at the main since the head broke on the water softener.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 01-24-2013, 07:00 AM   #15
cllecr's Avatar
Thanks for all the great advice and cautions...especially the reminder to check cupboards and storage for freezeable liquids... And to check our TV screen!
We decided to go ahead and winterize... and now we are staying a few more days with friends here in 80 Phoenix as the clean up process at home is going so slowly in frigid temps...will head back this weekend, meet with adjuster next week. Frozen underground septic pipe may not thaw till spring. Luckily does not affect whole house so we do have water/plumbing! At this rate, no telling how long we will need to be there to get the project finished, tho, so I guess our snowbird plans are officially on hold.
Our first time winterizing... ended up using the 5 gallons of antifreeze poured directly in freshwater tank and pumped through system as there is no siphon hose on the water pump and we would have to have one installed in the line. Couldn't get the anode tube out of the hot water heater yet...drained it from the bottom, tho, and bypassed it. Imagine the anode rod needs to come out to complete the draining?
Now thinking about washing/washing before we head home. Another first (waxing) with lots of choices! What kind of finish is our 2011 sunseeker 2400? (White fiberglass walls with decals). Apparently some waxes not good on some finishes?
There sure are a lot of things to learn as new RV owners..!!
Scott and Carol
2011 Sunseeker 2300
Life is an adventure!
new to us RV owners April 2012
2012- 100+ days camping + Panama cruise
2013- 60 nights in our RV so far (as of Aug 1)
cllecr is offline   Reply With Quote
Old 01-24-2013, 07:28 AM   #16
Herk7769's Avatar
If you did not get the anode out; how did you drain it? Using the plumbing to drain the hot water heater has risks. Bits of anode (a normal process) and calcium deposits can get swept into the cold water pipes when using the low point drains to drain the hot water heater.
When you hook up fresh water in the spring, that rubbish in the pipes can be pushed into faucets and the flush valve on the toilet causing low pressure and flush problems.
I would not use that technique next year.
Close the bypass system first, then using the appropriate socket, extension, and wrench to remove the anode and using a flush wand made for flushing out the heater (or a homemade one, like the photo) flush out the garbage from the bottom of the water heater.
Name:	Hot Water Tank Clean out Wand.jpg
Old 01-24-2013, 07:46 AM   #17
cllecr's Avatar
My DH and a friend who used to have an RV decided they could do it, by the time I arrived they said they couldn't get the "drain" open (what size socket is needed? 1"?)... So they drained it the hard way (indicating low point drain underneath). We even went out and bought a socket (thought we saw 7/8 needed somewhere)...so that didn't work.
Any way to flush that gunk out of the system to prevent potential low pressure problems?
Scott and Carol
2011 Sunseeker 2300
Old 01-24-2013, 10:17 AM   #18
Not something I would ever do since draining and flushing the tank of antifreeze is hard to do completely. However without disconnecting the pump inlet piping to drain it there isn't much else you could do. I installed a three way valve and siphon hose so it could be drained and serve as a point to supply the antifreeze.
You also should air blow or hand pump antifreeze in through the city water connection as the on board pump will not pump back through it. Maybe you could push something into it to unseat the backflow check valve and get back flow of antifreeze out through it.
ATVer is offline   Reply With Quote
Old 01-24-2013, 10:23 AM   #19
trudinator's Avatar
Originally Posted by ATVer View Post
Also certain TVs and computers screens can't handle the cold. I believe those called LCD (liquid crystal display) can be damaged at severe temps but LED types are ok.
We've never removed any of our televisions or electronics and we live in Wisconsin. it was -9 here yesterday morning. They're fine as long as you let them warm up before using them.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 01-24-2013, 10:41 AM   #20
cllecr's Avatar
Wow.... thought we had pretty much followed directions in the manual for winterizing (except for not being able to get the anode out of the hot water heater). Now it seems what we did was not advised on several levels. Should we open low point drains and drain the antifreeze out of the tank? Will we be able to get the antifreeze flushed out so we can drink fresh water from the tank again?? And why didn't the manual say anything about running antifreeze through the plumbing from the city water connection??
Also, could we have just disconnected a hose to the water pump and attached a siphon hose? Didn't see anything anywhere explaining how to do this, if so...
Beginning to wonder if we will actually ever get this stuff figured out before we ruin something.
