Old 07-26-2013, 08:55 PM   #11
My 2012 2300 was built in Sept 2011 and has no sign of cracking or bubbles.
tlf65 is offline   Reply With Quote
Old 07-26-2013, 09:18 PM   #12
Originally Posted by chad.wiseman View Post
I've noted along the edge of my fiberglass roof there are a number of spots where the non-skid fiberglass is not sticking to the roof. It has bubbled and has a little play. Is this something that I should worry about or common with the fiberglass roofs?
If it's not cracked or showing signs of distress it should be okay. I would walk on that area or flex it un-necessarily. It is installed by one person pushing down and horizontally on the roof fiber glass panel edge and a second person hitting the now vertical edge with a screw gun. If the first person doesn't keep the bend tight with the top of the roof structure it would be easy to get a bubbled area.
ATVer is offline   Reply With Quote
Old 07-27-2013, 08:01 AM   #13
Plain Old Member
ATVer's theory sounds spot on. I didn't get to see the roof being put on while I was there, but there was snow on the ground and it wasn't really cold inside. I did see a bunch of roofs ready to be installed, and they had that overlap that you referred to that is wrapped over the edge and secured. I can definitely see how that stress could cause the roof to lift / bubble a little at the edge. This is what mine's done in a few spots on the edge. Mine was built in the winter months.
Does the roof in fact overlap the side wall? I thought they told me it did. Wish I could've seen that part.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-27-2013, 08:13 AM   #14
Yes from what I recall. I wish I had felt the edges of the roofs on the floor to see how flexible they are.
Old 07-27-2013, 10:26 AM   #15
When in sheet form not attached to a backer and at room temperature it's very pliable and able to bend. It's the same material used on popup roofs and those typical have a front and rear bend at the roof to side slope.
mwebber78 is offline   Reply With Quote
Old 07-27-2013, 05:10 PM   #16
Are you sure this is the same material used on hard top campers? That stuff is pretty durable, and would certainly give me more confidence when walking on it.
Sun.ranger is offline   Reply With Quote
