Old 04-06-2013, 09:59 PM   #11
Got it figured out. Keep panel hot water switch off, turn on water pump, pull pin on switch on hot water heater, turn on and in 5 minutes hot water with electric hook up.
bigdog1001 is offline   Reply With Quote
Old 04-08-2013, 07:59 AM   #12
MotocrossCamper's Avatar
Glad to hear you got it!
MotocrossCamper is offline   Reply With Quote
Old 04-10-2013, 09:59 AM   #13
Mega Member
Water
I had similar confusion---the sticker is referring to the sewer connection directly under it. The other connection next to your City inlet fills your internal water storage.
rgarner is offline   Reply With Quote
Old 04-10-2013, 02:29 PM   #14
Yea that was the problem signage. What side is gray tank is it the left gate or right
Old 04-10-2013, 03:19 PM   #15
Grey tank should be the one more toward the rear. If your on the side looking at them that would put grey to the right and black to the left. Black should have a bigger diameter pipe coming into the Y. Your shower may have its own tank so look on the opposite side of the RV for another handle.
Old 04-10-2013, 04:22 PM   #16
Mega Member
Yes, in mine the bigger diameter tank is to the left is the black and the smaller--rearward one on the right is the grey. The galley water--which includes the shower---has it's own tank and the handle is on the opposite of the coach where the batteries are located---look to the right when you open the battery compartment door. Hope that helps.
Old 04-10-2013, 09:13 PM   #17
Ok gonna crawl under her tomorrow and have a peak.
Old 04-11-2013, 08:12 AM   #18
Sounds like my water heater adventure. On our RV the water heater switch on the inside panel only turns the gas heater on/off. The switch on the water heater only turns the electric heater on/off. You could, it seems, have both on, either on, or none on as they are not interconnected. I would have preferred a system like that on the fridge. The electric element is prone to burning out if actuated without water in the heater and that may be the reason for the pin in yours; ours didn't have one.
Geri is offline   Reply With Quote
Old 04-11-2013, 08:18 AM   #19
GM
bclemens's Avatar
Yet another area where we learned a bit.
On all our new units, we actually use a "gray" handle on the gray tank. Black handle on the black tank. Genius.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-11-2013, 11:04 AM   #20
Yes the grey tank is more towards the rear. There is also a tank for the shower. So when I go to dump I need to pull that Valve also or do I just keep it open all the time. On the control panel I see there is a level indicator for the galley is that the tank for the shower?
