Old 05-29-2014, 07:31 PM   #21
Unhappy
Finally found the time to remove water pump. SAS the plastic housing is cracked 50% around the seam.
Can the plastic housing be purchased separate. I have not seen any for sale anywhere.
Wildkats66 is offline   Reply With Quote
Old 05-29-2014, 07:35 PM   #22
Forgot to mention that I got the fill tube problem corrected. Just took the plastic fill tube and blew through the return screen line. I felt something give and walla, the tank fills. When I took the water pump out I removed the input "sieve" in the plastic housing and a bunch of plastic pieces came out. Might have been the problem and it just reared itself this year.
Old 06-01-2014, 12:31 AM   #23
I located the water pump lower housing only at Shopetsonline. Rather nice prince also.
tank, water, water tank
