Originally Posted by youroo
This is all correct,but I might add, Buy a 12" long piece of 1/2 Copper tubing and push it in the end of the Plastic hose! This will allow you to keep the Valve and fill hose (In the Fill opening) without it coming out and giving you a Cold Shower! It also prevents the plastic hose from (Getting the Droops) and shutting off the Flow! If you always have a Helper disregard this! Youroo!!
Thats a good idea youroo and if you put a slight "J " bend in the end you can hang it out of the fill hole,I know the FW fill port is high on a 3050/3051 ( over my head and i'm 5' 10") going to use that idea!
