Old 07-06-2015, 09:06 PM   #11
rbetzwieser's Avatar
Originally Posted by n-e-d View Post
Must use the same gauge the NFL uses for game balls
Lol!
rbetzwieser is offline   Reply With Quote
Old 07-08-2015, 01:22 AM   #12
Garrette's Avatar
If memory serves, there has been other post and the problem is in the spray foam that is applied over the air lines making it almost impossible to find the leak. Several members have rerun the air lines. I am a lucky one. My airbags might drop 10 lbs over a period of several months.
Garrette is offline   Reply With Quote
Old 07-08-2015, 05:44 AM   #13
deebarjay's Avatar
I can see chasing down a leak in a motorhome might be tuff...the help at rv establishments aint top notch....if you are nimble and are able to crawl under the vehicle [drive front end on ramps] and inflate bags to 80 psi then go at the lines and valves with brush and soapy water...with that much loss you should get bubbles. I had a western hauler type bed built for my last truck... put bags on and had zero leak or loss of pressure over 8 yrs [altho I was often changing pressure from 30 -80 psi depending on load].
deebarjay is offline   Reply With Quote
Old 07-08-2015, 09:20 AM   #14
Boso's Avatar
I have a friend that has had them on his 2012 f 250 toes fifth wheel with different pressures for towing and not but never leaked a lb in 3 years I will fix mine if camping world won't but not until it out of warranty and I have to
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 07-08-2015, 12:23 PM   #15
Hoglou's Avatar
home repair
Been there.. may be a worth your look at
Field repairs (air bag line)
I keep spare line and connectors in the coach at all times, as long as I hav'em I won't need'em....
Hoglou westGA
KM4HQQ 146.640mhz
Old 07-08-2015, 02:31 PM   #16
Boso's Avatar
Will it ruin the connectors to pull tube out reseat it I did see entire repair kit for 37.00
Old 07-10-2015, 06:09 PM   #17
Hoglou's Avatar
I assume them to be consumables. I cut pass where my rub was and added a new connector. I did not try to salvage them. I did put split tubing over the entire run for future protection.
Hoglou westGA
KM4HQQ 146.640mhz
Old 07-10-2015, 07:21 PM   #18
Boso's Avatar
What I'm talking about is if I pull the tubing out of the connectors cut square and re insert to connectors that is if I can find a leak there at 100 psi over a few minutes some times it takes a few minutes to show a leak with soap if it is really a slow leak
Old 07-10-2015, 08:12 PM   #19
BendOrLarry's Avatar
I have installed 3 Firestone air bag systems. They all have had initial installation leaks. I have just removed the tube from the connectors, re-cut the tube reinsert, check for leak move on down the road. My last rig had the airbags on it for 6 years and it would loose a few pounds of air over a few months, but not enough to be an issue. Removing and reinserting into original connectors is no problem. Cut, reinsert until there are no more bubbles.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 07-10-2015, 09:46 PM   #20
Boso's Avatar
Thanks I think that's what I am going to have to do I have got leaks but no one can find them I have seen it take 15 minutes to find a leak keep spraying with soap solution but the pressure test would drop 2-3 psi and you might see just small bubbles only from almost constant soap testing but it will show if you can view the connections
