The air bags can be adjusted between 5 and 100 psi. Typically start at about 50-60 psi and adjust as needed to find the ride you like. Depends on many factors like load, whether or not you have a toad, etc. Higher pressure will be a little stiffer ride, which can help in crosswinds or with the rush of passing trucks.
When adding air, be careful. It takes very little. I use a tire inflator rather than a compressor to make sure not to overfill. They do tend to leak a little over time, so check at the beginning of each trip.
Trial and error will find the best for you. I use 65 psi with a full load and no toad.
2012 Forest River Sunseeker 2300 Chevy
