Old 11-12-2014, 12:46 PM   #1
First RV and trying to bypass the water heater to winterize
Do you know which valve(s) I should flip to bypass? There is one on the blue at the bottom... one on the red at the top... then one in between each. I'm guessing the blue (so water cannot flow into the tank) and the one on the red coming out of the tank, so it doesn't back flow into the tank?
jjlavin is offline   Reply With Quote
Old 11-12-2014, 12:49 PM   #2
Average Joe
MrJoe's Avatar
Turn each valve 90 degrees... all three
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 11-12-2014, 12:58 PM   #3
Here ya go. RV Water Heater Bypass Systems
Old 11-12-2014, 01:33 PM   #4
Sweeeet. Thanks guys
Old 11-12-2014, 01:53 PM   #5
Take The Road Less Travld
MuddauberE's Avatar
Turn the red and the blue (upper and Lower) ones off, then the bypass on (middle left) Or do as Mr. Joe said. same thing
"Take The Road Less Traveled"
2013 Rockwood Roo 233s
2017 Ford F-150 EB
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
Old 11-13-2014, 08:36 AM   #6
hockeytownmom's Avatar
I'm jealous you can see that much of your water heater! LOL
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 11-13-2014, 02:29 PM   #7
trdutch's Avatar
I've read somewhere that you can't see your valves on the Hot /w heater
This is very curious to me cause on a brand new unit it shouldn't be an issue
On my 2860ds I do have to open my living room/kitchen slide out so I can remove an under sink drawer, but then it's all right there, cold in,hot out and bypass.
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 11-13-2014, 05:46 PM   #8
On a 2300, the water heater is under the bed. On the bed platform there is a deck plate (small circular cover plate). You remove it and reach down in to change heater valves. You could see it if you look, but then you wouldn't have room to get an arm in there. Just do it by "feel". Not really hard. You can tell when you have a valve perpendicular to the pipe, or parallel to the pipe. Hardest part is holding the mattress up while you reach in there.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 11-13-2014, 08:32 PM   #9
Average Joe
MrJoe's Avatar
The 2450 is exactly the same.
Joe and Karen
Old 11-13-2014, 10:08 PM   #10
Folks, let's use some logic. If a handle on a valve is turned perpendicular to the pipe or hose, the valve is closed. If the handle on the valve is parallel with the hose, then the valve is open. In order to bypass the hot water heater, you close the valve on the hoses to and from the water heater and you open the valve between those two hoses.
budblack is offline   Reply With Quote
bypass, heater, water, water heater, winter, winterize
