Old 05-01-2019, 09:25 PM   #1
Lucdeso's Avatar
Fixed solar panel
How do you fixe your solar pannel on the roof? Sunseeker 3010DS
Luc
2015 Sunseeker 3010DS
Lucdeso is offline   Reply With Quote
Old 05-02-2019, 08:48 AM   #2
I'm not saying my way is the best way, but it has worked well for me. I put down a bed of 3M Marine Adhesive Sealant Fast Cure 5200 under the mounts. I then put two stainless steel screws through each mount into pre-drilled holes. The last step was to cover the mounts with Dycor.
The panels have been on the roof for about two and a half years and are holding nicely.
2016 Sunseeker 2300C
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts." - Bertrand Russell
SS Cruiser is offline   Reply With Quote
Old 05-02-2019, 10:17 AM   #3
2012 Solera
I did similar - adhesive plus SS screws - but used Dicor self leveling both under and over the mounts. Also added four extra mounts to the panel. Five + years, probably 70K miles, no issues.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 05-02-2019, 11:09 AM   #4
Lucdeso's Avatar
Do you look for the roof stud to screw in or it does not matter. (with a stud detector).
tank you
Luc
Old 05-02-2019, 10:18 PM   #5
2012 Solera
I did not look and do not think any of my screws are into a roof stud. Just screwed to the roof plywood through the fiberglass.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 05-02-2019, 10:30 PM   #6
Same here. I considered position on the roof relative to other items which might cast shadows more important than hitting a stud. The panels are quite secure mounted as they are.
Old 05-03-2019, 07:26 AM   #7
Lucdeso's Avatar
Thank you very much gentlemen, this reassures me and last question the length of the screws.
Luc
Old 05-03-2019, 07:54 AM   #8
I used inch stainless screws. I coated the screw threads with adhesive before driving them in.
Old 05-03-2019, 08:23 AM   #9
2012 Solera
Same for me, as I remember.
JLeising
2012 Solera "S"
Calif SF Bay Area
solar
