Old 07-27-2016, 10:09 PM   #1
Floor Crack
While under the RV tracing a cable I noticed a crack across the entire white floor board. The crack goes from side to side and is located between gas tank and. Water tank. Is this a problem? I am thinking there are layers of flooring.
bdifonzo is offline   Reply With Quote
Old 07-27-2016, 10:09 PM   #2
This is on a 2015 Sunseeker 3170
Old 07-27-2016, 10:24 PM   #3
The white plastic sheet is for waterproofing. If it's still under warranty have the dealer seal it. If it's out of warranty, just seal it with tape. Others may respond with their recommendations, but I've seen Eternabond recommended for roof repairs. It should be fine for your repair. I've never needed to use anything on our floor or roof.
The attached floor cross section was posted on this forum a while back. I'm not sure if yours is the same.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
