Old 05-30-2014, 02:57 PM   #1
GM
bclemens's Avatar
Ford E450 Custom Alignment Specs
This was posted in other threads, I figured I would post it in its own thread so that others can find it.
FYI, we align to Ford "required" specs from the factory which can be pretty broad.
This is a MUCH tighter spec that goes above and beyond what Ford specs in and will require adjustable cam bushings.
Proceed at your own risk. We also found that it helps to have some mileage on the rig, as weight seems to help the chassis settle a bit.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 05-30-2014, 08:30 PM   #2
tmhyer's Avatar
Thanks for posting again. Ive saved the attachment.
2014 Sunseeker 3010DS, 2001 Jeep Cherokee toad
tmhyer is offline   Reply With Quote
Old 05-31-2014, 02:58 PM   #3
rbetzwieser's Avatar
Just got mine done yesterday. Drives like a car!
Sent from my SCH-I545 using Forest River Forums mobile app
rbetzwieser is offline   Reply With Quote
Old 05-31-2014, 03:52 PM   #4
How many miles did you put on the MH before you had the alignment?
rekwiat is offline   Reply With Quote
Old 05-31-2014, 03:53 PM   #5
2500 miles. I have a 2014 3050s.
Old 06-02-2014, 04:54 PM   #6
Displaced2's Avatar
2013 Lexington 265GTS. Alignment after tire recall at 10000 miles and major difference in handling
Displaced2 is offline   Reply With Quote
Old 06-02-2014, 05:45 PM   #7
Is this custom alignment specs for any E450 chassis used in a MH?
Do you bring these specs to the dealer / alignment shop and tell them to align to these specs?
jst3 is offline   Reply With Quote
Old 06-03-2014, 10:10 AM   #8
GM
bclemens's Avatar
I can't for everyone...but it works in the E450's that we build. Sunseeker, Forester, Lexington
Old 06-04-2014, 01:08 PM   #9
Any idea if these specs are the same for a E350? (2011 Sunseeker 2300)
PhilG is offline   Reply With Quote
Old 06-06-2014, 07:13 PM   #10
got an appt on the 6-13 to getter re aligned
Phelpo
phelpo is offline   Reply With Quote
alignment
