Old 03-25-2013, 08:41 PM   #1
Ford tranny "clank"
We have a brand new 2014 Sunseeker with the E450. Does anyone else hear and feel a "clank" sound when shifting the van into Park? Seems to do it every time when going from D or R into park. I've only had Toyota trucks so not sure if this is typical.
4Gcampers is offline   Reply With Quote
Old 03-26-2013, 09:26 AM   #2
GM
bclemens's Avatar
I've never noticed anything when shifting and as a factory rep I drive a ton of them.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 03-26-2013, 09:44 AM   #3
Yikes. That wasn't what I wanted to hear.
Old 03-26-2013, 09:51 AM   #4
Mine "clanks" also. Always thought it was a normal sound. Its a 2011, 3100SS Sunseeker.
parker21 is offline   Reply With Quote
Old 03-26-2013, 10:26 AM   #5
niedobry1's Avatar
Ours clanks also 2010 3100SS
niedobry1 is offline   Reply With Quote
Old 03-26-2013, 10:33 AM   #6
Sounds like there are others. Are you able to feel it in column shifter? Mine kind of clinks into park but you feel in the column. Lots moving parts with that drivetrain.
Old 03-26-2013, 03:09 PM   #7
zook's Avatar
Mine clanks as well.. normal Ford sound.. 2012 3120DS.
zook is offline   Reply With Quote
Old 03-26-2013, 08:19 PM   #8
Mine clanks also when shifting on an incline. Seemed normal to me as I have heard it on other heavy Ford vehicles.
ATVer is offline   Reply With Quote
Old 03-26-2013, 08:32 PM   #9
Our 2011 Sunseeker 3100 (2010 Ford E-450 chassis) sometimes clanks when I shift it into park. It's the driveshaft, which is quite long and has several intermediate supports. When in drive or reverse, the driveshaft is tight against any slack. When you engage park, it sort of recoils to its unloaded position. As long as you are fully stopped when you shift into park, don't worry about it. If you are still rolling and it clanks, let it be a reminder to don't do that! You could probably prevent it by shutting the engine off with it still in drive or reverse, then putting it into park. That way there would be no tension on the driveshaft when you shift it.
Old 03-26-2013, 08:57 PM   #10
Well that makes perfect since. I thought it sounded like it may be coming from the font end of the drive shaft. That's a good point about trying it with engine off. I'll try that in the am. At least others hear it too. I called my dealer who said I should get it to ford, they never have heard of it before.
