Old 10-03-2014, 08:24 PM   #31
Thanks everyone for your feedback on the Forest River quality. It is obvious that some have problems while others do not. It seems to boil down to how well the dealer solves the issues. My wife and I have settled on and ordered a 2015 Forester 2651S. I look forward to many miles ahead of us and hopefully running across some of you on the road.
Thanks again.
Gilm2113 is offline   Reply With Quote
Old 10-04-2014, 01:21 AM   #32
Appleguy1991's Avatar
I have been driving/using my 3121 for more than 2 years to date. I am very happy with my rig, I have been in 5 states and no major problems whatsoever. I love my Forest River!
Appleguy1991 is offline   Reply With Quote
Old 10-04-2014, 09:42 AM   #33
Thank you Appleguy, we are looking forward to do the same. I appreciate you response.
Old 10-04-2014, 10:33 AM   #34
On my first trip to Id and Wy. Didn't need the furnace in central Ca, but mornings here are nippy! When I turn it on the air conditioner blows cold air out or ceiling vents and heater vent blow hot air. Is this the way it is supposed to be? Also, what is the difference between "furnace" and "heat pump"? Any advice would be appreciated. Thanks.
Yorkranchgalnguy is offline   Reply With Quote
Old 10-04-2014, 10:58 AM   #35
Mikegjax's Avatar
The heat pump acts like an AC in reverse. It puts heat in by taking cold out.
Your heat pump position runs the AC for heat and the furnace position uses propane for heat.
The heat pump is more efficient when the out side temp is not very cold. In the 30's it can't handle heating as well. When the heat pump does not give you what you need, then switch to furnace. They both should not be running at the same time.
If you have your fan set on "auto" you should not be getting cold air from the AC when the furnace is selected.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 10-04-2014, 11:29 AM   #36
Thank you so much! Problem solved. The only other problem I've had is the shower latch broke so door opens when cornering. I'm sure easy dealer fix just have to find one in Boise! Thanks again,Mike.
Old 10-04-2014, 12:04 PM   #37
Mikegjax's Avatar
Are you sure the latch is broken? They can pop off easily and usually just snap back on.
2014 Solera 24R
USN Retired
Old 10-07-2014, 08:51 PM   #38
Sorry I didn't get back sooner. Yep- the part on the door is missing, and a funny looking thing is on the frame. Camping world said they have to order it, but the warranty guy hasn't called back yet. Any ideas on a temp fix? Don't want the shower door to get broken slamming on corners. Thanks. Yorkgng
Old 10-08-2014, 04:45 AM   #39
I had two of these break in the first six months so I gave up. I had mounted a towel bar on the wall high above the toilet, so I took a small bungee cord and put it on the bar and the top of the door--holding the door open during travel. It works great. Others have put something like a dowel rod in the bottom track of the door in the open position to hold it open during travel.
You can call FR directly and they will send you a new latch under warranty--but like I said, my replacement one also broke on bumpy roads.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 10-08-2014, 05:40 AM   #40
trdutch's Avatar
Originally Posted by seamoorebeemoore View Post
We just put down payment on a 3170 (2014). Wondering, what, if any modifications has anyone done. We are def new to RvLife any recommendations would be appreciated .
Start a new thread with this topic.im sure you will get many replies
I'm afraid you won't get many responses here cause people on this thread are talking about FR quality issues. ;-)
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is online now   Reply With Quote
class c, forest river, quality
