2013 3010DS with the double door Domestic.
Freezers getting cold enough to make ice but won't keep food Frozen have it turned up all the way tried just electric for a few days then we tried running just the propane for a few days still no results we even played with the setting and learned the higher the number the colder the freezer.
Any ideas or anybody else experienced the same thing and can come up with some suggestions thanks so much for your time for reading this and definitely your reply.
Andy
We also have the same 4 door refrigerator as you folks. Check to make sure the secondary gas valve on the back of the fridge is open. This bit us once. (Take the outside vent cover off. In the lower left corner you will see a small knurled valve with a slot in it. Make sure the slot is in line with the gas line. This valve needs to be open to get a full flue flame). Sorry, I don't have a picture available. Hope this discription helps!
Andy
That does seem odd. These aren't the most powerful freezers in the world by any means. Is this needed during camping or can you freeze the food first at home?
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
I have the same problem it's a hit or miss problem sometimes it works perfect. Make sure up are as level as you can be then pull the cover off outside and turn a fan on the opening to try and move the air around coils. Never had any problems with the Norcold brand, but Dometics are a piece of - - - - just my opinion
We always place some of the retail "cold packs" in our freezer, when we precool the refrigerator/freezer. That keeps the temperature fairly constant and helps keep everything else in there colder. We put two on the shelf in the freezer. They really do help.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
Right On !!!
We always put our meat in frozen !!!
No jokes Please !!!
We turned our fridge in Wednesday eve,,, Thursday afternoon I put 6 ziplock bags of Ice that we had made in the freezer,,, we will be packing the fridge tomorrow,,, Saturday,,, moving most of the Ice to a cooler,,, and heading North on Sundry AM !!!
