Old 01-26-2019, 06:30 PM   #1
Fresh water drain location?
We were told to drain our fresh water tank before storing but we can't seem to find the drain... can someone please help. We have a 2017 Sunseeker 2500TS class C....
Think we found it!!
Debbie and George is offline   Reply With Quote
Old 01-26-2019, 07:07 PM   #2
RedLdr1's Avatar
Welcome to the forum. Open up your water bay, on the passenger side, and you will see a valve in the back that may be hidden by the black metal cover. That valve drains your fresh water tank. Opening a faucet will act as a vacuum breaker and let the water drain quicker...
Wayne and Christine
2019 R-Pod RP-180 10th Anniversary Edition
2018 Ford F-150 SuperCrew Lariat FX4 (4X4) 3.0L Power Stroke Diesel
RedLdr1 is offline   Reply With Quote
Old 01-26-2019, 07:30 PM   #3
Denver To Yuma In 90 Days
I've never heard that...
I would think that all the drains in the sinks and shower would be more than enough!
Someone "doing it for years with no problems" doesn't mean YOU should!
2015 Heartland Prowler P292 5'ver, Reese 16K Pro Slider Hitch
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear end
JohnD10 is online now   Reply With Quote
Old 01-26-2019, 07:38 PM   #4
RedLdr1's Avatar
One of those weird things I learned from a RV tech during a PDI a couple RV's back. Sometimes my fresh tank starts draining instantly other times I have to open a faucet to get a decent flow. Since all the drains are on the grey tank system that might be the reason.
Wayne and Christine
Old 01-26-2019, 07:52 PM   #5
Mr. Dan's Avatar
Drains in the sinks and showers are connected to gray/galley waste tanks. This OP is trying to drain the fresh water tank - not connected to gray/galley tanks.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Old 01-27-2019, 04:48 PM   #6
X2
The fresh water tank vent should be enough, but sometimes it is not. Opening a faucet helps to vent it.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 01-27-2019, 05:37 PM   #7
cavie's Avatar
How would the DRAINS help drain the FRESH WATER TANK?
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 01-27-2019, 06:02 PM   #8
Sorry...
I must have misread the OP...
That being said, I've never had better drain flow with the faucets open.
But I do open the cap on the fresh tank fill connection.
THAT is all you really need to do.
Old 01-27-2019, 06:08 PM   #9
2016 GTS Sunseeker 2430S
We have a 2016 Sunseeker 2430 GTS.
Our fresh water drain is under the bed. Not very convenient!
Our bathroom sink drains into our BLACK water tank.
Gizmosmom is offline   Reply With Quote
Old 01-27-2019, 10:06 PM   #10
Think we found it!!
I have a 2017 Sunseeker CDWS 2650. The freshwater tank is under the bed. The drain valve is on the very left side of that compartment at the very back way down at the bottom.
fkampa is offline   Reply With Quote
cat, drain, fresh water, location, water
