Old 03-05-2016, 12:08 PM   #11
Gold Miner At Heart
Papa-t's Avatar
I use a small diameter hose like you use for a washing machine inlet water line/hose. Use the one that has a female end. Cut the hose about a foot from female end. Now you can screw a regular water hose to the female end and the small diameter hose will fit down into the water fill opening. Just push it down in about 10 inches and you can fill and the hose won't jump out.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
Papa-t is offline   Reply With Quote
Old 03-05-2016, 12:58 PM   #12
On my old TT I had the same issue. Figured out that spiders made a nest in the vent tube (small opening above the fill opening). By holding the hose in place and forcing water in it blew out the vent tube. From there on I had no more issues filling FW tank. Just a thought.
Gregg & Denise
2006 F-350 CC LB 6.0 Diesel 4x4 DRW
2014 Heritage Glen 366bh
2015 Camping---"162 Nights"
2016--Moved in camper 11/2015 while
getting ready to sell sticks-N-bricks
PIGMAN is offline   Reply With Quote
Old 03-05-2016, 12:59 PM   #13
I've had the same problem filling my FW tank. My solution is to lift he passenger side a few inches with the Bigfoot levelers. If I didn't have them, I would drive up onto some leveling blocks. This is a bit inconvenient, but it works.
We've been on the road for the past three months, but when I get home I'll remove the bed platform and see if I can improve on the fill hose routing.
2016 Sunseeker 2300C
SS Cruiser is offline   Reply With Quote
Old 03-05-2016, 02:31 PM   #14
Mine is in for service now for this issue. When they disassembled the water fill, they found the tube ran upward, was buckled and leaking. The service rep said, " you know water doesn't flow uphill, eh"?
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 03-05-2016, 02:42 PM   #15
I bought my 2008 Lexington used and have the same problem...the FW fill is almost horizontal as well. My Nephew recently showed me an adapter that he uses to fill his fish tanks with, which is the adapter attached to a long, clear, thinner hose. I'm going to find one of those!
Greywolf My Pack
2008 Forest River Lexington 28 ft
Flat Tow 2012 Ford Escape
Greywolf My Pack is offline   Reply With Quote
Old 03-05-2016, 02:46 PM   #16
This is the result of cutting the tube a bit too long. And instead of test fitting and sizing property, they shoved it in, and screwed it down...
Eric Jackson
2015 Solera 24R
Old 03-05-2016, 02:46 PM   #17
Some great ideas here...which is why I always come here first What I ended up doing is a combination of what a couple of you guys suggested:
1. Got a very cheap (thin) garden hose for about $10...connect it to my white hose, cut off the other end. Now I have a hose that will actually go into that hole a little further.
2. Use my leveling system on manual and put the two passenger side jacks down which gives me the pitch I need
Presto....all done
2015 Sunseeker 3010DS
jeffreymhardy is offline   Reply With Quote
Old 03-05-2016, 02:46 PM   #18
nomad297's Avatar
Originally Posted by youroo View Post
Notice!! be careful with this item,you could/can turn your FWT into a "Water Balloon"!High pressure water with lots of flow will overcome the little "Air Vent"! Youroo!!
youroo, this device has its own vents, also. I've filled my tank all the way until water squirted out of the vents at 60psi with no problems.
Bruce
Old 03-05-2016, 02:56 PM   #19
Mr. Dan's Avatar
Presto....all done
Thanks for reporting back, jeffreymhardy.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110; booked = 0
Old 03-05-2016, 04:07 PM   #20
My fix
I have a Sunseeker and I have the same issue. I use the long funnel and I use high water pressure. I cover the air vent hole when I fill the tankle. I release the air from the vent...some water blows out so stand back then cover the hole again and repeat as needed. I chech the level inside. Good luck.
waterwoman is offline   Reply With Quote
fresh water, water
