Old 03-06-2016, 03:44 PM   #31
Here is what we use, works great, fills the water tank with no backups.
Water Tank Filler with Shut-Off Valve - Camco 40003 - Fresh Water Pumps - Camping World
Kevin & Judy is offline   Reply With Quote
Old 03-06-2016, 04:05 PM   #32
Ok,now I will give some input! We use this one also,just 1 little Mod to keep it from Blowing/Falling out while filling! I put a 12" piece of Copper tube 1/2" inside the clear hose about 3",never had it come out since! Youroo!!
Old 03-06-2016, 04:14 PM   #33
Have never had a problem with it coming out.
Old 03-06-2016, 04:41 PM   #34
WFD
ditto....use the same one..does the trick just fine....best of all...it's cheap! Also cheap from Amazon if you are ordering other stuff, and just as cheap at Walmart.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 03-06-2016, 05:22 PM   #35
Blackhat6mike's Avatar
You might want to put a piece of nylon screen into the vent tube to keep the mud dobbers and spiders out. Air will pass through OK, but not critters.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 03-06-2016, 05:47 PM   #36
Hoglou's Avatar
Ditto on a good recovery... hope you heal fast.
best..
Hoglou westGA
KM4HQQ 146.640mhz
Old 03-07-2016, 06:51 AM   #37
Wolverine 1945's Avatar
Originally Posted by Boots49 View Post
I hope the knee is doing well. I know running is out, my doctor said no running or jumping. Golf in 2 months.
1 is Great,, 1 is ok !!!
Wolverine 1945 is offline   Reply With Quote
Old 03-07-2016, 07:02 AM   #38
That is what we used on the end of our inline filter,,,
until the hose fell off and into the FR tank !!!
I think if I were to buy another one,,, I would glue the hose on !!!
Old 03-07-2016, 08:01 PM   #39
I had a problem getting my FW tank to full if coach leaned toward fill side. Used Robot check but still seemed problematic. I took a two foot section off old FW hose and stuck it in the opening like Robot Check, worked great, don't know why there's a shut off on Robot Check needed a cut off valve. I'm also starting to use the brass quick release connections due to finger joints getting weak and sore, helps greatly.
Harry & Alice
Furkid Spruce
2014 Sunseeker 2650s
Friend of Bill and Lois
since May 30, 1975
Happywanderer is offline   Reply With Quote
Old 03-08-2016, 07:17 AM   #40
Our biggest problem was always water in the air vent,,,
even with the air vent was clear,,, it's a SLOW fill !!!
fresh water, water
