Old 03-08-2016, 12:16 PM   #41
Water in the air vent might be from the air vent hose being some how misplaced. On the 2650, the tank and pump are located under the bed. We lift the mattress, the a plywood sheet and there it all is,mostly. Two hoses enter the FW tank, make sure each has no kinks as you trace them back to the external fill connection. Start filling and watch what happens inside. Good luck.
Harry & Alice
Furkid Spruce
2014 Sunseeker 2650s
Friend of Bill and Lois
since May 30, 1975
Happywanderer is offline   Reply With Quote
Old 03-09-2016, 07:24 AM   #42
Wolverine 1945's Avatar
If you try to put to mulch water in to fast,,, you will force water in to the air vent,,,
and then tank will no longer accept water,,, and will spit it back @ you !!!
Wolverine 1945 is offline   Reply With Quote
fresh water, water
