01-05-2017, 12:27 PM
Fresh Water Tank
I'm having a hard time filling my fresh water tank. The hose has fallen or is kinked. I'm assuming I need to remove the bed and start there. Any help would really be appreciated.
01-05-2017, 12:30 PM
The fixer teller people on here will need to know some details about the unit so you might want to get that ready
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
01-05-2017, 01:14 PM
It's a 2014 3010 Sunseeker. The water just backs out. Is the line under the bed? There are some very knowledgeable people here so I hope someone can give me some direction.
01-06-2017, 11:39 PM
Before you start dismantling you might try some compressed air down the vent at the inlet. Worked for me when it would only take water slowly.
01-07-2017, 08:03 AM
Chief tinkerer
Bednarski, we have the same rig. Yes, you can lift the wood cover closest to the outside wall under your bed and see the fill line. You can see that it is at a very low angle since the fill port is under the slide and possibly has a droop between the outside and the tank inlet. With this droop, the weight of incoming water has to push water uphill into the tank. Mine had a strap attached to the bed framing that was supposed to eliminate the droop, but it was broken and let the line sag. Also, as mentioned elsewhere, we carry a three foot piece of hose with just a female connector which can be carefully inserted to get past this droop.
Gary
2017 SunSeeker 3010DS
01-07-2017, 04:14 PM
Thanks for the great information. How did you permanently fix the droop in the line? I'll tackle this job next week if I can be assured that the line will be fixed for good.
01-07-2017, 07:18 PM
Chief tinkerer
Glad to help. Found the broken strap late one evening while camping on our last trip of the season and didn't have anything with me to replace it with at the time. So, it's on the list. You know, the list of things we all have that we are going to get around to.
Gary
Gary
01-07-2017, 08:14 PM
geezer with gadgets
Gary
Now you can take care of that list!
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
01-07-2017, 08:24 PM
Chief tinkerer
LOL, ty Dave!
Gary
Gary
02-25-2017, 08:33 PM
Chief tinkerer
Used your Round Tuit today and put zip ties in two places under the bed (where the remnants of the OEM ones still were) to remove the sag. Can now fill with the hose wide open, which came in handy today because I was de-winterizing and sanitizing.
Gary
02-26-2017, 11:34 PM
geezer with gadgets
Glad it came in handy!
Take good care of it!
04-21-2017, 12:56 AM
Fresh Water Tank
Trying to help some friends who just bought a 2017 2500TS with the fresh water fill. Seems to be a kinked vent tube. Water backs up immediately when filling with water hose. Any idea where I can find it on this model ? Thx
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
04-25-2017, 12:38 AM
Does anyone own a 2500ts on this forum and if so , can you tell me where the vent hose and fresh water tank are hidden. Thx
1968 tent trailer
1985 Jamboree 23 ft
04-29-2017, 06:37 AM
Under the bed is fresh water tank...I've had trouble adding water myself it seems if you push your garden hose into the opening it will fill must be a pressure thing.
05-01-2017, 12:54 AM
Thx Chuck.
1968 tent trailer
1985 Jamboree 23 ft
05-01-2017, 02:23 PM
I had the same problem on my 2013 3010DS. I bought this little attachment for 6 bucks a it has an on off and about 8 inches of tube after that. I can fill full blast with this thing its awsome. I will post a link or a pic of it..
2013 Forest River Sunseeker 3010DS
05-01-2017, 02:39 PM
Just be careful with those... we've had several reports here when they shoved them down the fill tubes and pulled the 8" hose off them when removing leaving the 8" hose stuck in the fill tube.
Many have added a hose clamp to keep the hose on.
05-03-2017, 12:02 AM
What others have said previously first check fill and vent tubes ensuring no sags or kinks in line. I just bought a device called Secure-fill. This is a small hose attached to a vented cap that attaches to the fresh water gravity fill inlet. You attach your hose and you can easily fill the FW tank. I'll make a short video tomorrow and post it here to give everyone a first hand look at it. It worked great!
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
05-03-2017, 12:32 PM
Here is a short YouTube video on the Secure-Fill i just purchased. It certainly worked for me.
https://youtu.be/9HcjtK_k7Qs
2011 Jeep JK Toad
05-06-2017, 09:09 PM
It's not the vent tube. It's the fill tube running uphill from the fill opening. Like others, we use a 2 or 3 foot section of water fill hose, and push it most of the way in.
2014 Sunseeker 2300 Chevy
