Old 08-30-2015, 09:40 PM   #11
hockeytownmom's Avatar
I will check under the bed to see what I can see. 😊 we only use it to keep some water in while on the road to flush.
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 09-01-2015, 06:15 AM   #12
Mike001's Avatar
I had the same problem, my breather hose had a kink in it.
Mike001 is offline   Reply With Quote
Old 09-02-2015, 02:24 PM   #13
No kinks or anything unusual that I could see.
Kristina & Family
Old 09-02-2015, 03:45 PM   #14
widogmom's Avatar
Same problem, I just slow my roll and throttle back on the filler gizmo. Takes half an hour to fill the tank. Fortunately we have "city" water most places we camp.
2015 Sunseeker 3010DS
2005 Honda Element (toad)
Now, Voyager, sail thou forth, to seek and find.
widogmom is offline   Reply With Quote
Old 09-02-2015, 03:52 PM   #15
knockando's Avatar
Shoot. No kinks OR the hose isn't below the inlet on the actual tank, that could create a trap where the water will occasionally "blow back" at you.
knockando is offline   Reply With Quote
Old 09-11-2015, 08:57 PM   #16
Just turn up the pressure of the water going fresh tank and it will blow out the air bubble in the line thru your little air hole on the left hand corner on the fill cap
goots is offline   Reply With Quote
Old 09-14-2015, 08:15 PM   #17
I had a similar problem when filling fresh water tank sometimes it would come back out as fast as i was putting it in. I did two things that seems to resolve the issue
1 under the bed i had a big sag in the hose so i used tie-wraps to pull the hose up thus eliminating the sag
2 i purchased one of those fillers from camping world and then bought a piece of clear hose and replaced the short one which came on the filler.
chucknviv is offline   Reply With Quote
Old 09-14-2015, 08:22 PM   #18
rclogg's Avatar
I use a clear hose and push air into the vent opening causing the check valve to open, I can then fill the tank full. Works every time.
'14 Cummins Dually Aisin 4.10
'07 FR Cardinal LE 30RK
'03 Cummins Dually 45RF
'01 Exiss 300MT Weekender
A wife and two dogs, isn't that enough?
rclogg is offline   Reply With Quote
Old 09-14-2015, 08:43 PM   #19
osgood's Avatar
I keep a rubber washer fill hose that I cut the end off of. One end has garden hose connection and its about 4' long. i put about half it in the filler tube. After that it doesnt spit back out until full.
osgood is offline   Reply With Quote
Old 09-14-2015, 09:12 PM   #20
My hose was mounted about an inch too high under the bed. I moved it down a little and it stopped spitting water out the filler. Good luck.
Sent from my Nexus 6 using Tapatalk
TakeItEasy is offline   Reply With Quote
fresh water, tank, water, water tank
