08-30-2015, 10:07 AM
Fresh water tank
I'm having a hard time putting water in the tank. It just comes right back out. Other times, no problem at all. I can't figure out what's going on. Anyone else experience this?
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
08-30-2015, 10:13 AM
I don't have a problem like you, but I bought this filler for my fresh water tank. It's really great because it twists and locks onto the opening and there is a short hose to get the water flowing where it's supposed to. It seems expensive for what it is, but it was well worth it for me.
Secure-Fill - SNL SNL1SF - Faucets & Inlets - Camping World
Bruce
08-30-2015, 10:27 AM
geezer with gadgets
I was getting ready to ask the same question!
I haven't had a problem until yesterday. I put a little water in, then it just gurgles out, I stop until all is calm, put a little more it, etc...
Looking for a solution also.
Thanks for asking hockeytownmom!
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
08-30-2015, 10:59 AM
Try slowing up the flow. I find that sometimes the hose in the input blocks the airflow (I know there is a air relief) but I think the input hose from the connection into the tank cannot handle the high flow that comes from a hose. That is why it fails sometimes. Different flow rate. Easy and worth a try.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
08-30-2015, 12:06 PM
I had the.pressure turned down very low, though.
Kristina
2021 F150 XLT
Previously:
08-30-2015, 12:08 PM
That is really neat, I'll be picking one of those up.
Kristina
2021 F150 XLT
Previously:
08-30-2015, 02:55 PM
Picking up what? One of the Secure Fills I linked to?
Bruce
08-30-2015, 04:52 PM
I had the same problem as you last month. Tried putting it in really slow and also using a funnel I bought from an RV store and nothing worked. Finally took it in and the fill hose was positioned like a rolling highway. They fixed the hose on two ends for better flow and it goes in fine now.
08-30-2015, 05:03 PM
Sounds like your tank vent is stopped up, probably with water forming an air-lock. Blow the vent out and try again. Many times, when the trailer is moved around, water will flow into the vent tube and stop venting. You may also have a low point in your vent line.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
08-30-2015, 08:40 PM
I would put a beer on it that you have a low spot on the fill hose that runs to the tank. Same thing happened to us until I got under the bed and noticed the line had a big sag. Propped it up with a 3" pvc and now we can fill in about 5 min!
08-30-2015, 09:40 PM
I will check under the bed to see what I can see. 😊 we only use it to keep some water in while on the road to flush.
Kristina
2021 F150 XLT
Previously:
09-01-2015, 06:15 AM
I had the same problem, my breather hose had a kink in it.
09-02-2015, 02:24 PM
No kinks or anything unusual that I could see.
Kristina
2021 F150 XLT
Previously:
09-02-2015, 03:45 PM
Same problem, I just slow my roll and throttle back on the filler gizmo. Takes half an hour to fill the tank. Fortunately we have "city" water most places we camp.
2015 Sunseeker 3010DS
2005 Honda Element (toad)
Now, Voyager, sail thou forth, to seek and find.
09-02-2015, 03:52 PM
Shoot. No kinks OR the hose isn't below the inlet on the actual tank, that could create a trap where the water will occasionally "blow back" at you.
09-11-2015, 08:57 PM
Just turn up the pressure of the water going fresh tank and it will blow out the air bubble in the line thru your little air hole on the left hand corner on the fill cap
09-14-2015, 08:15 PM
I had a similar problem when filling fresh water tank sometimes it would come back out as fast as i was putting it in. I did two things that seems to resolve the issue
1 under the bed i had a big sag in the hose so i used tie-wraps to pull the hose up thus eliminating the sag
2 i purchased one of those fillers from camping world and then bought a piece of clear hose and replaced the short one which came on the filler.
09-14-2015, 08:22 PM
I use a clear hose and push air into the vent opening causing the check valve to open, I can then fill the tank full. Works every time.
'14 Cummins Dually Aisin 4.10
'07 FR Cardinal LE 30RK
'03 Cummins Dually 45RF
'01 Exiss 300MT Weekender
A wife and two dogs, isn't that enough?
09-14-2015, 08:43 PM
I keep a rubber washer fill hose that I cut the end off of. One end has garden hose connection and its about 4' long. i put about half it in the filler tube. After that it doesnt spit back out until full.
09-14-2015, 09:12 PM
My hose was mounted about an inch too high under the bed. I moved it down a little and it stopped spitting water out the filler. Good luck.
Sent from my Nexus 6 using Tapatalk
2015 Sunseeker 3170ds
