I ran a wire down the breather hose and when I pulled it out there was gunk on the end.I ran the wire up and down several times.Filled the fill hose with water and then used a compressor to blow into the breather hose.The water in the fill hose bubbled then blew out.The water now drains into the tank.I now keep the breather hole plugged until I fill. A screen or plug should be installed at the factory.
