I've got a 2014 2250 Sunseeker, with the bedroom in a side slide out in the back, and I'm looking for the fresh water tank valve.Does anyone know where it is?
Do you mean the valve to drain the freshwater tank? On the 2300, you open the outside compartment to the rear of the right rear tires. In the back of the compartment is a small black door. Remove that for access to water filter and pump and valve for draining fresh water tank. Probably same setup on yours.
2012 Forest River Sunseeker 2300 Chevy
Thank you. I'll give it a try. But my unit's bed is on the left side (slide out), and the fresh water tank is also on the left side, so I suspect its somewhere in that vicinity.
The 2450 is exactly the same as Bill's.
Joe and Karen
2014 Sunseeker 2450sf
As a new owner of a used 2012 Forest River 2250S Sunseeker, I thought I would chime in. I found the freshwater tank drain valve, today, behind a panel on the left side within the outside storage compartment located beneath the slide. Removal of Phillip's head screws is required for access (should have been a hinged door with latch IMHO).
As you devil into the deal you will find more "should haves" I simply suggest you make what ever kind of modifications you want.
In this case a length of piano hinge and some screws should do the trick.
Before and after pictures will help newer members if they wish to do the same.
We have a 2015 22QB and also cannot find the fresh water valve. Have looked in all the places suggested above.
Sharon n Gary
RNKNP (Retired No Kids No Pets)
Always looking for great wine!
2015 Coachmen Freelander 22QBF | 1980 Toyota truck toad
22QB is a different builder/division than the 2250.
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
